RE: dsplink issues
Hi Phil - these samples should work fine on beagle. Did you set the mem=80M(or similar) on the kernel command line to reserve the dsp memory from being used by the linux side? The base dsplink samples don't need this much memory, but this should be plenty to verify the samples are working correctly. Could you try this if not please and let me know?
~roger
