Hi Jason,
Thank you for your quick response, but I have gotten myself into bigger problem. I deleted the NAND flash boot and other files…So now I can’t even boot from my SD card, even when I push and hold the user button. Even the 2 USER LED’s do not ever light up…
To anyone how can help me,
Is there a way to boot directly from the SD card without going through the NAND at all, because the user bottom is not heling, should I re-flash the NAND, what image or u-boot (X-loader) should I download?
I have a XDS510 USB JTAG POD (14pin-not keyed),is that the correct JTAG for the Beagleboard and what flash downloader software tool do I need to flash the NAND, is it UniFlash V3.1 ?
I remember on the BeagelBone Black I moved the 100K Ohm resistor R68 to R93 and forced the board to always automatically boot from the SD Card. Is there something I can change on the BeagleBoard hardware schematically to do the same ?
Saad Namou
Sr. Electrical Engineer
tel: 781.575.5545 | saad_namou@instron.com
825 University Avenue, Norwood, MA 02062 | www.instron.com
To receive testing tips and application stories, subscribe to our newsletters
