On Fri, 7 Jul 2017 17:52:25 -0700 (PDT), Mala Dies
<functt@gmail.com> declaimed the following:
Hello Rob,
Seth here, again. I tried out the *(reading.value / 4096.0) * 1800;* in the
software. It tells me that I have a temperature of -49.99 degrees in
Celsius. I am trying to make believe my calculations from the software are
correct with the inside/climate controlled temp. in this house.
So, what value are you getting for "reading.value" and does it make
sense?
Working backwards (with the above correction)
function displayTemp(reading)
var millivolts = reading.value * 1800;
var tempC = (millivolts - 500) / 10;
for a temperature of -49.99
-49.99 = (mv - 500) / 10
-499.9 = (mv - 500)
0.1 = mv
0.1 = (rv / 4096) * 1800
5.555E-5 = rv / 4096
0.227 = rv
For all practical purposes, your -49.99 is what would be expected if
you were reading ground (actual ground would result in -50degC).
Comparing the same circuit and (similar) code between (Monk)
Programming the Beaglebone Black and (Chavan) Programming the BeagleBone...
Neither use the 4096 divisor; apparently bonescript is supposed to already
scale the ADC value to 0.0-1.0; the 4096 would be needed if you were
getting the actual ADC counter (12-bit). They differ on the temperature
equation (beyond the difference between mV and V)
v = rv * 1.8
vs
mv = rv * 1800
degC = (100 * v) - 50
vs
degC = (mv - 500) / 10
If "rv" were 0.5, then
v = 0.9 mv = 900
degC = 40.0 degC = 40.0
... so the two formulation will display the same value. Now, if rv were 0.0
it gives
v = 0.0 mv = 0
degC = -50 degC = -50
Note that the sensor is rated for a minimum of -40degC, so there must
be some residual voltage on the ADC at all times -- equivalent to 0.1v (or
0.055 from the ADC)
According to the spec sheet, the TMP36 has an offset of 0.5v, and
produces 0.75v at 25degC.
degC = (v - 0.5) * 100
is the direct translation, and again, an ADC value of 0.0 gives a -50degC.
