Re:
Excerpts from Ben Gamari's message of Wed Jan 20 14:47:23 -0500 2010:
Bcc:
Subject: GPIO chip select support in omap2_mcspi driver
It seems like the rough idea is to add a cs_gpio field to the device
struct (omap2_mcspi) and add the appropriate code to the
omap2_mcspi_force_cs() to bring cs_gpio high or low if it is valid. The
potential problem I can see with this is that omap2_mcspi_set_enable()
is called to enable the channel before the force_cs() is called (in
omap2_mcspi_work()). If I'm interpreting the documentation correctly,
the enable bit starts the clocks, meaning that the chip will begin
clocking out data before CS is brought high. I must be missing something
here, no?
Could someone comment on how this ordering works? As I said, it seems to
me like the SPI controller starts sending before CS is brought high.
I would appreciate any feedback. Thanks!
- Ben
