GPIO 7 has been defined in beagle's board file in the kernel. See board-omap3beagle.c for more details.
GPIOs which are defined there cannot be exported to /sys/class/gpio. In this case you can use the user button with event interface,
The code looks interesting, however I'm wanting to read the USER
button from the shell prompt via the /sys file system. I can blink
the LEDs that way, but I don't know how to read the button.
At least one option is to remove the reference to GPIO 7 from the board file and then recompile kernel. That will let you use the /sys method.
