I just rebuilt x-loader after a few changes (-march=armv7a is invalid
for gcc4.3, -march=armv7-a should be used instead) against the
beagleboard uboot, but it halts after:
Texas Instruments X-Loader 1.41
Starting on with MMC
Is that expected when using PRCM_CLK_CFG2_332MHZ over
PRCM_CLK_CFG2_266MHZ?
So, does someone have a working xloader.bin that enables L2 cache and
runs the CPU at more than 381MHz?
regards,
Koen
Which tool chain are you using to compile this u-boot?
Building and executing u-boot and x-loader should be very simple if you follow the instructions on wiki
http://code.google.com/p/beagleboard/wiki/BeagleSourceCode
http://code.google.com/p/beagleboard/wiki/BootingBeagleBoard
You should not change this, I will give out the u-boot and x-loader for 500 MPU with L2 Cache soon.
I have already sent them.
Let me know if you find issues.
Khasim
