I tried latest OMAP git (2.6.26-rc1-omap1, git from today, HEAD == 42fa072e237427675752bb9da05bf406bff19719, "OMAP3 EVM: enable ethernet support") on OMAP3 based BeagleBoard and it immediately stops after output of Kernel command line (with CONFIG_DEBUG_LL enabled):
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
<5>Kernel command line: console=ttyS2,115200n8 ...
Assuming that it might be related to recent clock or powerdomain changes [1] I switched back to HEAD == "Fix remaining sparse warnings in arch/arm/mach-omap2" (git-checkout cdda2a9adbc5421f4857e0313afc6c189f422e25) and system now boots again.
Any idea?
Can you try git-bisect to see which one breaks booting on beagle?
Any idea?
-- cut --
> git bisect bad
757f0b4ad6b0fd4377c2ee512fc595b5778aa3ac is first bad commit
commit 757f0b4ad6b0fd4377c2ee512fc595b5778aa3ac
Author: Paul Walmsley <paul@pwsan.com>
powerdomain: convert pwrdm_mutex to rwsem
Convert pwrdm_mutex to pwrdm_rwsem to avoid trying to relock mutex in the
event that the pwrdm_for_each() callback function calls something that
triggers a pwrdm_lookup(). Problem found by Jouni Högander
<jouni.hogander@nokia.com>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Signed-off-by: Tony Lindgren <tony@atomide.com>
:040000 040000 833450098951bb58b4753d0ec641e8b1e767c419 eb7329d713ff74ae46d0a8145f80cd4a259b8fc8 M arch
-- cut --
-- cut --
> git bisect bad
Date: Fri May 9 14:45:24 2008 -0700
Curious, this boots fine on 3430sdp, and there's nothing in that patch
that should affect Beagle in particular.
Could you try building cdda2a9adbc5421f4857e0313afc6c189f422e25 and see if
that also breaks? Of the recent OMAP-specific patches, that's the one
that I would suspect. And if that also breaks, maybe try the one
before it, 352b2e24c5cd193a40ae376fec85665f2660aeb1 ?
Curious, this boots fine on 3430sdp, and there's nothing in that patch that should affect Beagle in particular.
Could you try building cdda2a9adbc5421f4857e0313afc6c189f422e25 and see if that also breaks?
Hmm, I think cdda2a9a... was the first one working for me:
If you like, I can recheck again. But would be better if anybody else could confirm this, just in case I missed anything. Hint, hint
Of the recent OMAP-specific patches, that's the one that I would suspect. And if that also breaks, maybe try the one before it, 352b2e24c5cd193a40ae376fec85665f2660aeb1 ?
In a private mail I got:
-- cut --
To add another data point: on the OMAP3 EVM warm boots fail as described, but cold boots complete successfully.
-- cut --
Unfortunately, he couldn't confirm which commit is failing for him yet.
On Beagle we currently boot using bootrom starting from MMC. Like with TWL, it seems that the pre-initialization by bootrom has some influence on kernel behaviour.
