Yea I know this isn't really a beaglebone question but thought I would ask here first since we use beaglebone for prototyping.
My boss wanted me to conduct some 5GHz WiFi testing so my usually tp-link and TI wilink solutions are no good as they are 2.4GHz adapters only.
Anyone recommend any dual band or 5GHz only solutions that have decent Linux driver support?
USB or SDIO...
Thanks!
I've had a lot of luck with these in a 5Ghz only wifi network (2.4 was
swamped at that location)
http://wireless.kernel.org/en/users/Drivers/carl9170#available_devices
But... they are getting harder to find now days. Most of those are
dual 2.4/5...
Make sure to check the model revision:
https://wikidevi.com/wiki/Main_Page
oem's like to build whatever chipset they get cheap..
Great! Thanks Robert, appreciate the recommendation.
-Jesse @ Gibson
As you noted it is hard to tell which ones use chipsets that support 5GHz so I order two D-Link DWA-160 and two TP-LINK TL-WN821N.
10-20$ each…
I’ll post back here when I get them and run some 5GHz tests…
So far as a wpa_supplicant client this one seems to be working for me:
https://wikidevi.com/wiki/D-Link_DWA-182_rev_C1
Never did get hostapd working but moved on…
