Hi
Now my boot time, [from the power up to console message display] is around 40 sec.
I want to reduce it further till 25 sec. below are the existing dmesg log of my beaglebone board.
ubuntu@beaglebone:~$ dmesg
[ 0.000000] Linux version 4.19.94-ti-r36 (voodoo@w1-imx6q-wandboard-2gb) (gcc version 7.4.0 (Ubuntu/Linaro 7.4.0-1ubuntu1~18.04.1)) #1bionic SMP PREEMPT Mon Mar 2 15:55:39 UTC 2020
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Green Wireless
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 48 MiB at 0x9c800000
[ 0.000000] On node 0 totalpages: 130560
[ 0.000000] Normal zone: 1148 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 130560 pages, LIFO batch:31
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] random: get_random_bytes called from start_kernel+0xa0/0x508 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu s39628 r8192 d21812 u69632
[ 0.000000] pcpu-alloc: s39628 r8192 d21812 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129412
[ 0.000000] Kernel command line: console=ttyO0,115200n8 bone_capemgr.enable_partno=BB-UART2 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 rng_core.default_quality=100 quiet
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 445240K/522240K available (13312K kernel code, 1156K rwdata, 4444K rodata, 1024K init, 355K bss, 27848K reserved, 49152K cma-reserved, 0K highmem)
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0000000 - 0xff800000 ( 504 MB)
lowmem : 0xc0000000 - 0xdfe00000 ( 510 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0x(ptrval) - 0x(ptrval) (14304 kB)
.init : 0x(ptrval) - 0x(ptrval) (1024 kB)
.data : 0x(ptrval) - 0x(ptrval) (1157 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 356 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] ftrace: allocating 42638 entries in 126 pages
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000015] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000032] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000041] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000776] timer_probe: no matching timers found
[ 0.001015] Console: colour dummy device 80x30
[ 0.001045] WARNING: Your ‘console=ttyO0’ has been replaced by ‘ttyS0’
[ 0.001049] This ensures that you still see kernel messages. Please
[ 0.001053] update your kernel commandline.
[ 0.001113] Calibrating delay loop… 995.32 BogoMIPS (lpj=1990656)
[ 0.046823] pid_max: default: 32768 minimum: 301
[ 0.047115] Security Framework initialized
[ 0.047128] Yama: becoming mindful.
[ 0.047277] AppArmor: AppArmor initialized
[ 0.047390] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.047401] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.048512] CPU: Testing write buffer coherency: ok
[ 0.048574] CPU0: Spectre v2: using BPIALL workaround
[ 0.049060] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.070931] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.078845] rcu: Hierarchical SRCU implementation.
[ 0.090150] EFI services will not be available.
[ 0.094854] smp: Bringing up secondary CPUs …
[ 0.094868] smp: Brought up 1 node, 1 CPU
[ 0.094878] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[ 0.094885] CPU: All CPU(s) started in SVC mode.
[ 0.096625] devtmpfs: initialized
[ 0.111301] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.111957] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.111980] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.115993] xor: measuring software checksum speed
[ 0.154830] arm4regs : 1217.000 MB/sec
[ 0.194819] 8regs : 1091.000 MB/sec
[ 0.234817] 32regs : 1166.000 MB/sec
[ 0.274817] neon : 1674.000 MB/sec
[ 0.274823] xor: using function: neon (1674.000 MB/sec)
[ 0.274842] pinctrl core: initialized pinctrl subsystem
[ 0.276224] NET: Registered protocol family 16
[ 0.282409] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.320970] l4_wkup_cm:clk:0010:0: failed to disable
[ 0.361185] audit: initializing netlink subsys (disabled)
[ 0.362484] cpuidle: using governor menu
[ 0.366950] audit: type=2000 audit(0.352:1): state=initialized audit_enabled=0 res=1
[ 0.371356] OMAP GPIO hardware version 0.1
[ 0.372222] GPIO line 61 (LS_BUF_EN) hogged as output/high
[ 0.374382] GPIO line 112 (MCASP0_AHCLKR) hogged as output/low
[ 0.385181] No ATAGs?
[ 0.385193] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.410995] raid6: using algorithm neonx8 gen() 0 MB/s
[ 0.411007] raid6: … xor() 0 MB/s, rmw enabled
[ 0.411014] raid6: using neon recovery algorithm
[ 0.418374] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.422470] SCSI subsystem initialized
[ 0.426957] libata version 3.00 loaded.
[ 0.427279] usbcore: registered new interface driver usbfs
[ 0.427340] usbcore: registered new interface driver hub
[ 0.427468] usbcore: registered new device driver usb
[ 0.429713] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 0.429985] media: Linux media interface: v0.10
[ 0.430038] videodev: Linux video capture interface: v2.00
[ 0.430181] pps_core: LinuxPPS API ver. 1 registered
[ 0.430209] PTP clock support registered
[ 0.430982] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.435207] Advanced Linux Sound Architecture Driver Initialized.
[ 0.436017] NetLabel: Initializing
[ 0.436028] NetLabel: domain hash size = 128
[ 0.436032] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.436135] NetLabel: unlabeled traffic allowed by default
[ 0.437305] clocksource: Switched to clocksource timer1
[ 0.602117] VFS: Disk quotas dquot_6.6.0
[ 0.602222] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.603114] AppArmor: AppArmor Filesystem Enabled
[ 0.615534] NET: Registered protocol family 2
[ 0.616616] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.616650] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.616692] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.616749] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.616880] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.616904] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.617128] NET: Registered protocol family 1
[ 0.630527] RPC: Registered named UNIX socket transport module.
[ 0.630537] RPC: Registered udp transport module.
[ 0.630542] RPC: Registered tcp transport module.
[ 0.630547] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.632068] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.634849] Initialise system trusted keyrings
[ 0.635238] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.642604] zbud: loaded
[ 0.650066] NFS: Registering the id_resolver key type
[ 0.650131] Key type id_resolver registered
[ 0.650137] Key type id_legacy registered
[ 0.650154] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.650522] fuse init (API version 7.27)
[ 0.661042] Key type asymmetric registered
[ 0.661056] Asymmetric key parser ‘x509’ registered
[ 0.661158] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.665770] io scheduler noop registered
[ 0.665782] io scheduler deadline registered
[ 0.666104] io scheduler cfq registered (default)
[ 0.666115] io scheduler mq-deadline registered
[ 0.668661] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[ 0.670251] gpio-of-helper ocp:cape-universal: ready
[ 0.672937] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 0.675145] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.678923] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 38, base_baud = 3000000) is a 8250
[ 0.695842] console [ttyS0] enabled
[ 0.697066] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 39, base_baud = 3000000) is a 8250
[ 0.698356] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 40, base_baud = 3000000) is a 8250
[ 0.701031] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 0.705490] random: fast init done
[ 0.705828] random: crng init done
[ 0.825090] libphy: Fixed MDIO Bus: probed
[ 0.827046] usbcore: registered new interface driver smsc95xx
[ 0.827927] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.827976] ehci-platform: EHCI generic platform driver
[ 0.828185] ehci-omap: OMAP-EHCI Host Controller driver
[ 0.828728] usbcore: registered new interface driver usb-storage
[ 0.831465] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator
[ 0.831640] am335x-phy-driver 47401300.usb-phy: Linked as a consumer to regulator.0
[ 0.834523] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 0.834700] am335x-phy-driver 47401b00.usb-phy: Linked as a consumer to regulator.0
[ 0.838043] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 0.838084] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 0.838448] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.838459] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.838467] usb usb1: Product: MUSB HDRC host driver
[ 0.838474] usb usb1: Manufacturer: Linux 4.19.94-ti-r36 musb-hcd
[ 0.838481] usb usb1: SerialNumber: musb-hdrc.1
[ 0.839293] hub 1-0:1.0: USB hub found
[ 0.839355] hub 1-0:1.0: 1 port detected
[ 0.850608] omap_rtc 44e3e000.rtc: already running
[ 0.851292] omap_rtc 44e3e000.rtc: registered as rtc0
[ 0.852580] i2c /dev entries driver
[ 0.853253] Driver for 1-wire Dallas network protocol.
[ 0.855645] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 0.856124] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[ 0.857655] cpuidle: enable-method property ‘ti,am3352’ found operations
[ 0.858255] sdhci: Secure Digital Host Controller Interface driver
[ 0.858262] sdhci: Copyright(c) Pierre Ossman
[ 0.858792] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[ 0.858803] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 0.859422] omap_hsmmc 48060000.mmc: Linked as a consumer to regulator.2
[ 0.886849] omap_hsmmc 481d8000.mmc: Linked as a consumer to regulator.2
[ 0.910663] omap_hsmmc 47810000.mmc: Linked as a consumer to regulator.1
[ 0.951112] mmc1: new high speed MMC card at address 0001
[ 0.956478] mmcblk1: mmc1:0001 Q2J54A 3.64 GiB
[ 0.957105] mmcblk1boot0: mmc1:0001 Q2J54A partition 1 2.00 MiB
[ 0.957836] mmcblk1boot1: mmc1:0001 Q2J54A partition 2 2.00 MiB
[ 0.958197] mmcblk1rpmb: mmc1:0001 Q2J54A partition 3 512 KiB, chardev (242:0)
[ 0.964213] mmcblk1: p1
[ 1.013738] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.015773] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.016492] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 1.016740] omap-aes 53500000.aes: will run requests pump with realtime priority
[ 1.019406] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 1.023051] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.023419] omap_hsmmc 47810000.mmc: card claims to support voltages below defined range
[ 1.024017] usbcore: registered new interface driver usbhid
[ 1.024024] usbhid: USB HID core driver
[ 1.025008] remoteproc remoteproc0: wkup_m3 is available
[ 1.030746] gnss: GNSS driver registered with major 239
[ 1.037253] mmc2: new high speed SDIO card at address 0001
[ 1.038327] wireguard: WireGuard 0.0.20191219 loaded. See www.wireguard.com for information.
[ 1.038337] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld Jason@zx2c4.com. All Rights Reserved.
[ 1.039586] NET: Registered protocol family 10
[ 1.047812] Segment Routing with IPv6
[ 1.047947] mip6: Mobile IPv6
[ 1.047966] NET: Registered protocol family 17
[ 1.048080] Key type dns_resolver registered
[ 1.048087] mpls_gso: MPLS GSO support
[ 1.048462] ThumbEE CPU extension supported.
[ 1.048477] Registering SWP/SWPB emulation handler
[ 1.048487] omap_voltage_late_init: Voltage driver support not added
[ 1.055664] PM: Cannot get wkup_m3_ipc handle
[ 1.061757] registered taskstats version 1
[ 1.061767] Loading compiled-in X.509 certificates
[ 1.061905] zswap: loaded using pool lzo/zbud
[ 1.064948] Btrfs loaded, crc32c=crc32c-generic
[ 1.065057] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.118881] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[ 1.119706] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[ 1.120303] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 1.121169] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.121373] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.123168] remoteproc remoteproc0: powering up wkup_m3
[ 1.123288] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
[ 1.126686] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 1.126705] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x193
[ 1.127064] cpu cpu0: Linked as a consumer to regulator.4
[ 1.127169] cpu cpu0: Dropping the link to regulator.4
[ 1.127736] cpu cpu0: Linked as a consumer to regulator.4
[ 1.129507] PM: bootloader does not support rtc-only!
[ 1.130607] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:46:28 UTC (946687588)
[ 1.131393] ALSA device list:
[ 1.131400] No soundcards found.
[ 1.147174] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.147281] VFS: Mounted root (ext4 filesystem) readonly on device 179:1.
[ 1.148279] devtmpfs: mounted
[ 1.154451] Freeing unused kernel memory: 1024K
[ 1.155183] Run /sbin/init as init process
[ 1.245447] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 1.395341] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
[ 1.395358] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.395366] usb 1-1: Product: USB2.0 Hub
[ 1.396911] hub 1-1:1.0: USB hub found
[ 1.397267] hub 1-1:1.0: 4 ports detected
[ 1.506647] systemd[1]: System time before build time, advancing clock.
[ 1.628501] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.629230] systemd[1]: Detected architecture arm.
[ 1.653820] systemd[1]: Set hostname to .
[ 1.689472] usb 1-1.1: new low-speed USB device number 3 using musb-hdrc
[ 1.796466] usb 1-1.1: New USB device found, idVendor=413c, idProduct=2113, bcdDevice= 1.08
[ 1.796483] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 1.796491] usb 1-1.1: Product: Dell KB216 Wired Keyboard
[ 1.803948] input: Dell KB216 Wired Keyboard as /devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1/usb1/1-1/1-1.1/1-1.1:1.0/0003:413C:2113.0001/input/input1
[ 1.862305] hid-generic 0003:413C:2113.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-musb-hdrc.1-1.1/input0
[ 1.869513] input: Dell KB216 Wired Keyboard System Control as /devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1/usb1/1-1/1-1.1/1-1.1:1.1/0003:413C:2113.0002/input/input2
[ 1.929785] input: Dell KB216 Wired Keyboard Consumer Control as /devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1/usb1/1-1/1-1.1/1-1.1:1.1/0003:413C:2113.0002/input/input3
[ 1.930333] hid-generic 0003:413C:2113.0002: input,hidraw1: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-musb-hdrc.1-1.1/input1
[ 2.009546] usb 1-1.4: new low-speed USB device number 4 using musb-hdrc
[ 2.089551] usb 1-1.4: device descriptor read/64, error -32
[ 2.285481] usb 1-1.4: device descriptor read/64, error -32
[ 2.481472] usb 1-1.4: new low-speed USB device number 5 using musb-hdrc
[ 2.561452] usb 1-1.4: device descriptor read/64, error -32
[ 2.753470] usb 1-1.4: device descriptor read/64, error -32
[ 2.828438] systemd[1]: Created slice User and Session Slice.
[ 2.828974] systemd[1]: Reached target Swap.
[ 2.829845] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 2.831934] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.832168] systemd[1]: Reached target Remote File Systems.
[ 2.834084] systemd[1]: Created slice System Slice.
[ 2.834903] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 2.865868] usb 1-1-port4: attempt power cycle
[ 3.469468] usb 1-1.4: new low-speed USB device number 6 using musb-hdrc
[ 3.885496] usb 1-1.4: device not accepting address 6, error -32
[ 3.989483] usb 1-1.4: new low-speed USB device number 7 using musb-hdrc
[ 4.289533] EXT4-fs (mmcblk1p1): re-mounted. Opts: errors=remount-ro
[ 4.405419] usb 1-1.4: device not accepting address 7, error -32
[ 4.435153] usb 1-1-port4: unable to enumerate USB device
[ 4.615016] systemd-journald[144]: Received request to flush runtime journal from PID 1
[ 13.060804] Bluetooth: Core ver 2.22
[ 13.060968] NET: Registered protocol family 31
[ 13.060978] Bluetooth: HCI device and connection manager initialized
[ 13.061006] Bluetooth: HCI socket layer initialized
[ 13.061020] Bluetooth: L2CAP socket layer initialized
[ 13.061076] Bluetooth: SCO socket layer initialized
[ 14.352453] input: BRLTTY 5.4 Linux Screen Driver Keyboard as /devices/virtual/input/input4
[ 31.721632] wlan-en-regulator: disabling
[ 46.898563] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 46.908629] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 48.838829] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 48.872572] wlcore: loaded
[ 49.474429] wlcore: PHY firmware version: Rev 8.2.0.0.240
[ 49.518365] wlcore: firmware booted (Rev 8.9.0.0.76)
[ 49.534132] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 51.541997] wlan0: authenticate with 50:2b:73:2f:60:81
[ 51.548875] wlan0: send auth to 50:2b:73:2f:60:81 (try 1/3)
[ 51.586392] wlan0: authenticated
[ 51.589980] wlan0: associate with 50:2b:73:2f:60:81 (try 1/3)
[ 51.599824] wlan0: RX AssocResp from 50:2b:73:2f:60:81 (capab=0xc11 status=0 aid=9)
[ 51.610042] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 51.615269] wlan0: associated
[ 51.697657] cryptd: max_cpu_qlen set to 1000
[ 51.773890] wlcore: Association completed.
[ 62.719318] using random self ethernet address
[ 62.719336] using random host ethernet address
[ 63.027125] using random self ethernet address
[ 63.027142] using random host ethernet address
[ 63.193779] usb0: HOST MAC e4:15:f6:f5:8a:0d
[ 63.197119] usb0: MAC e4:15:f6:f5:8a:0c
[ 63.207435] usb1: HOST MAC e4:15:f6:f5:8a:0f
[ 63.208192] usb1: MAC e4:15:f6:f5:8a:10
[ 63.359203] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 63.649893] configfs-gadget gadget: high-speed config #1: c
[ 63.651463] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 65.017957] Bluetooth: HCI UART driver ver 2.3
[ 65.017977] Bluetooth: HCI UART protocol H4 registered
[ 65.019448] Bluetooth: HCI UART protocol LL registered
[ 65.019458] Bluetooth: HCI UART protocol ATH3K registered
[ 65.019595] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 65.883284] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 65.883300] Bluetooth: BNEP filters: protocol multicast
[ 65.884153] Bluetooth: BNEP socket layer initialized
[ 66.276579] Bluetooth: RFCOMM TTY layer initialized
[ 66.276624] Bluetooth: RFCOMM socket layer initialized
[ 66.276682] Bluetooth: RFCOMM ver 1.11
Can I further reduce the bootup time with few more second?
At-least console message should get display withing 25 sec.?
Can I change any initialization sequence so that I can get the booting message more early ?
Karishma Jaiswal
