Reducing the bootup time and some miscellaneous Qs
I am starting with Linux (a few weeks now), so the Q might be obvious to
some, but seems daunting to me.
I want to boot up the system as fast as possible and display my
application after that. Boot-up time of less than 5 seconds is very much
desirable.
Currently, the project will do the following:
1. Display some graphics stuff (GUI using GTK+ and custom widgets) on a
high resolution monitor.
2. Access the data on the serial port, store it on the USB flash drive
or MMC (if possible), use some GPIO on the board and interface a RTC.
3. Safely shutdown, whenever asked to so.
I have already downloaded OE and worked on it for a while. I have also
got my small application running on it :-D. I have been looking at the
recipes and they are hard to understand (at least for a beginner like
me).
The GUI for the application will be built using GTK+, so I would require
X, and other dependencies that GTK+ requires.
Now, to the actual Qs:
1. How to go about reducing the boot-up time? And removing the unwanted
components? I had thought of using the base-image and the have a script
run the console from the SD card to install everything that is required.
OR
Use the existing X11 Angstrom image and modify the bitbake recipes. I am
not able to decide, which seems to be the more efficient way.
OR
something else, which I have not thought of.
2. This is a very general one. I want to control the GPIO ports, and the
serial port and other stuff like that (I2C for RTC). So, what is the
approach that should be taken? I know one has to write a driver, so
whether these drivers are already implemented or some of them are
implemented and some not. And where to look for these drivers?
Thanks for reading this longish email. I appreciate the time you have
taken to read it.
-Deven
Hi Deven,
desirable.
Under 5 seconds sounds pretty much impossible. Just loading the kernel from flash or SD takes ~5 seconds on my setups.
For GPIO you might want to check these threads which were helpful for me:
  http://groups.google.com/group/beagleboard/msg/c623a16637625685
  http://groups.google.com/group/beagleboard/browse_thread/thread/be52908485cf1add/616972bf1e572b61
  http://groups.google.com/group/beagleboard/browse_thread/thread/cd2300fb60cc01b/2d3419107dda7867
Using I2C2 on Beagle board requires few things:
  - Set correct MUX values for relevant pins either in U-Boot or in kernel. I
    prefer U-Boot at the moment
  - In kernel source tree add entry for I2C2 in file board-omap3beagle.c. Just
    search look for I2C.
  - Check kernel's documentation on I2C, especially file dev-interface if you
    want to use I2C in userspace without the need to write any special drivers.
For RTC check this:
  http://groups.google.com/group/beagleboard/browse_frm/thread/331e5ddd950b73c0
Check out this: http://lwn.net/Articles/299483/
There is also a fastboot git (don't have the address handy)
still of course SD causes some overhead but loading the kernel itself
should definitely be done in less than 1 second.
If I load the kernel in u-boot it is less than a second before the
prompt returns.
But of course also time is lost in mlo, u-boot etc.
Frans.
