Regarding Beaglebone Black
Respected sir,
I am Mallem Kumar from Kwangwoon University South Korea Seoul.
in my project I am using Beagle Bone Black, I need one more USB post and Ethernet port.
I have some doubts about BBB please help me.
  1. i am replacing mini USB PC connector to USB port it is possible or not.
  2. what is difference between Boot switch and Reset button.
  3. can you please suggest me how can i connect one more CAN bus to the processor, what are the pins can i use to connect a new Ethernet port.
please help me sir.
https://github.com/CircuitCo/BeagleBone-Black/blob/master/BBB_SRM.pdf?raw=true
On Wed, 7 Dec 2016 14:35:58 +0900, Kumar Ddk
<kumar.eceb7@gmail.com> declaimed the
following:
Ethernet port.
  The easiest solution would be to connect a powered USB hub to the USB
host port of the BBB -- and then connect a USB<>Ethernet adapter (I'm
presuming current Linux builds have support for them).
  Ethernet is more than just a pair of I/O pins -- there are isolation
transformers and line drivers conditioning the signals.
https://www.neweggbusiness.com/Product/Product.aspx?Item=9B-33-114-057&nm_mc=KNC-GoogleBiz-PC&cm_mmc=KNC-GoogleBiz-PC-_-pla-_-Network+-+Interface+Cards-_-9B-33-114-057&gclid=CLefo6Op4tACFdi6wAodtYoDxg
(don't bother with the gigabit versions -- BBB USB 2 can't take advantage
of them)
1) i am replacing mini USB PC connector to USB port it is possible or not.
  The mini connector is a /client/ connector, the other is a host
connector... The drivers are much different between them.
