Can any one give me some hints on which settings are required in assembler flags to use VMRS or VMSR instructions with cross compiler arm-2007q3–arm-none-linux-gnueabi which i am using. This instructions work perfectly fine on RVDS but it throws error " bad instruction" while I try to compile using the cross compiler tool chain.
arm-2007q3--arm-none-linux-gnueabi which i am using. This instructions work
The gnu assembler doesn't support all the new UAL mnemonics. Use the
old FMRX and FMXR names.
