Reloading original board config
During the process of modifying something in the nand i migh have corrupted it? How could i restore the Rev C Board to its manufacturing config? Please advise,
Please follow the instructions found at http://code.google.com/p/beagleboard/wiki/BeagleboardRevCValidation
Hi All,
I’ve managed to get android up running on the pico projector however I can’t seem to find where I can drop down the screen resolution from 1280x720 to the pico’s HVGA 480x320. I tried:
setenv console=ttyS2,115200n8 noinitrd root=/dev/mmcblk0p2 video=omapfb:mode:480x320@50 init=/init rootfstype=ext3 rw rootdelay=1 nohz=off
However this seemed to stay at the original resolution. I have found some documentation on display metrics http://developer.android.com/reference/android/util/DisplayMetrics.html however I and yet to find how I can lower it.
Is anyone familiar with this?
Mark
you can change in your frame buffer driver to try to have fixed resolution or try to change in frameworks/base/libs/ui/EGLDisplaySurface.cpp in android source.
Thanks and Regards,
HarishKumar.V
