replacement for StrawsonDesign Robotic Cape Installer
Just getting started with bb blue. Watched the Arrow Video on getting started. At end it directed me to github for StrawsonDesign "Robotics_Cape_Installer.
Unfortunately the video is two years old and that package is no longer there. Those files are supposed to be on the board as shipped but I cannot find them. Is there a replacement for the Strawson package, or can you help me find the replacement that is allegedly on my board?
The git repo got renamed..
https://github.com/StrawsonDesign/librobotcontrol
got it. got librobotcontrol installed. Tried to run led.c. Would not compile and got message "
led.c:12:29: fatal error: rc/robotcontrol.h: No such file or directory
#include <rc/robotcontrol.h>
compilation terminated.
: recipe for target ‘led’ failed
make: *** [led] Error 1
I can see the led.h file in the directory above (in library/include/rc.
Do I need to do something to make these includes available to compiler. I am using cloud9.
Apologies for being an idiot. Just getting started. Thanks in advance.
Are you building this on a beaglebone or desktop?
I get missing .h files when doing it on a desktop (using cross compile tools)
building it on a Raspberry Pi, I get “build/cpu.o: file not recognized: File format not recognized” most likely because its not being build on the correct target.
Will have to find a bone to build it on.
amf
Builds fine on a beaglebone black
image was build with poky from Jumpnowtek
Linux beaglebone 5.0.9-jumpnow #1 Sat Apr 27 20:56:21 UTC 2019 armv7l armv7l armv7l GNU/Linux
root@beaglebone:~/librobotcontrol# make all
made: build/led.o
made: build/start_stop.o
made: build/version.o
made: build/pru/encoder_pru.o
made: build/pru/pru.o
made: build/pru/servo.o
made: build/math/matrix.o
made: build/math/ring_buffer.o
made: build/math/vector.o
made: build/math/quaternion.o
made: build/math/polynomial.o
made: build/math/algebra_common.o
made: build/math/algebra.o
made: build/math/kalman.o
made: build/math/filter.o
made: build/math/other.o
made: build/model.o
made: build/pthread.o
made: build/mpu/mpu.o
made: build/pinmux.o
made: build/mavlink_udp.o
made: build/cpu.o
made: build/bmp/bmp.o
made: build/deprecated.o
made: build/motor.o
made: build/dsm.o
made: build/time.o
made: build/io/gpio.o
made: build/io/encoder_eqep.o
made: build/io/adc.o
made: build/io/i2c.o
made: build/io/pwm.o
made: build/io/spi.o
made: build/io/uart.o
made: build/encoder.o
made: build/button.o
Done making lib/librobotcontrol.so.1.0.4
made: bin/rc_bind_dsm
made: bin/rc_test_servos
made: bin/rc_balance
made: bin/rc_test_algebra
made: bin/rc_test_filters
made: bin/rc_calibrate_accel
made: bin/rc_test_encoders
made: bin/rc_test_polynomial
made: bin/rc_test_dmp_tap
made: bin/rc_test_leds
made: bin/rc_test_mpu
made: bin/rc_test_adc
made: bin/rc_cpu
made: bin/rc_calibrate_gyro
made: bin/rc_test_motors
made: bin/rc_test_encoders_pru
made: bin/rc_benchmark_algebra
made: bin/rc_dsm_passthrough
made: bin/rc_test_kalman
made: bin/rc_test_escs
made: bin/rc_calibrate_escs
made: bin/rc_model
made: bin/rc_test_matrix
made: bin/rc_version
made: bin/rc_test_drivers
made: bin/rc_blink
made: bin/rc_test_bmp
made: bin/rc_test_encoders_eqep
made: bin/rc_altitude
made: bin/rc_check_battery
made: bin/rc_test_mavlink
made: bin/rc_test_pthread
made: bin/rc_test_complementary_filters
made: bin/rc_spi_loopback
made: bin/rc_calibrate_mag
made: bin/rc_calibrate_dsm
made: bin/rc_kill
made: bin/rc_test_vector
made: bin/rc_test_time
made: bin/rc_test_buttons
made: bin/rc_uart_loopback
made: bin/rc_test_dsm
made: bin/rc_battery_monitor
made: bin/rc_startup_routine
amf
