Replacing cape overlays
Hi!
I own a BB-VIEW-43 cape:
http://at.farnell.com/element14/bb-view-43/4-3inch-lcd-display-cape-for-beaglebone/dp/2364756#
By requesting "BB-BONE-LCD4-01" the cape manager loads the dtbo from
the cape's eeprom.
The cape is not using PWM for backlight but a plain gpio LED.
For whatever reasons the dtbo within the eeprom configures this LED
with a heartbeat trigger which is very annoying and needs fixing while
bootup.
What is the best way to fix that? How can I overlay the overlay? :wink:
My trivial approach was using the dts file from the cape sources
and creating a 02 version of the dtbo.
But of course the shipped dts sources does not match the shipped binary.
GPL violation?
It's actually worse then that, "BB-BONE-LCD4-01" = 16bit lcd display,
while the "BB-VIEW-43" is a 24bit..
Start with 3.8: ( am33x-v3.8 )
https://github.com/RobertCNelson/bb-kernel/
Then from the patch.sh script, uncomment this function call:
https://github.com/RobertCNelson/bb-kernel/blob/am33x-v3.8/patch.sh#L1134
#bb_view_lcd -> bb_view_lcd
Then run:
./build_deb.sh
and install the *.deb to the board.
If you still have time, return the "BB-VIEW-43" and pick up a 4D
Systems 4 inch lcd..
Hmmm, does this mean that the BB-VIEW-43's eeprom contains a completely
broken devicetree overlay? :frowning:
//richard
The eeprom only contains the "BB-BONE-LCD4-01" identifer... The
device tree overlay is built-into the kernel binary..
The BB-View-43, swapped the red/blue color channels, so there's a hack
for 3.8 to fix that..
https://github.com/RobertCNelson/bb-kernel/blob/am33x-v3.8/patches/bb_view_lcd/0002-sitara_red_blue_swap_workaround.patch
Hi!
the cape's eeprom.
Ahhh, it is in the kernel binary. Thanks for pointing this out.
I was about to ask why it works even when the file is not present in /lib/firmware/
Yeah, but setting to 24bits depth in xorg.conf also does the trick, no kernel patching needed.
//richard
