Reproducible System Crash using ubuntu-armhf 13.04
I’ve got a system crash that happens on my BeagleBone seemingly whenever I generate cpu loads > ~85%. Any ideas what could be causing this?
Here are the logs:
kmsg - https://gist.github.com/qrohlf/7690d13817bccc53613a
syslog - https://gist.github.com/qrohlf/7235cc3e6a54876d4cee
Per syslog, and error emit,
 BUG: scheduling while atomic: kworker ...
it appears there’s a scheduling issue (possibly triggered only during high cpu use).
May want to check threads like:
http://stackoverflow.com/questions/3537252/how-to-solve-bug-scheduling-while-atomic-swapper-0x00000103-0-cpu0-in-ts
and maybe even build that distro on your system so you can process the backtrace Or if Robert can spare a few cycles, he may be able to see where in the kernel code it is crashing…
/venkat
idk.. there seems to be lots of issues of 13.04 locking up on full
load whereas 12.10/Wheezy seem fine..
Yeah I’ve run Wheezy loaded as close to 100% load as possible for a couple hours, not problems.
