Ok, thank you. I will try to remove them and see if it works.
As I remember, I think I downloaded the image from: Index of /rootfs/bb.org/testing
I was following this instruction from @RobertCNelson: Readonly root problem - #2 by RobertCNelson but it’s possible that I chose the wrong image…
If I look in my: /var/log/kern.log it seems like the kernel recognize the ARMv7 Processor and my AM335x BeagleBone Black
BeagleBone kernel: [ 0.000000] Booting Linux on physical CPU 0x0
BeagleBone kernel: [ 0.000000] Linux version 5.4.38-ti-r8 (voodoo@x4-am57xx-beagle-x15-2gb) (gcc version 8.3.0 (Debian 8.3.0-6)) #1buster SMP PREEMPT Sat May 9 09:53:15 UTC 2020
BeagleBone kernel: [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
BeagleBone kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
BeagleBone kernel: [ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
BeagleBone kernel: [ 0.000000] Memory policy: Data cache writeback
BeagleBone kernel: [ 0.000000] efi: Getting EFI parameters from FDT:
BeagleBone kernel: [ 0.000000] efi: UEFI not found.
BeagleBone kernel: [ 0.000000] cma: Reserved 48 MiB at 0x9c800000
BeagleBone kernel: [ 0.000000] On node 0 totalpages: 130560
BeagleBone kernel: [ 0.000000] Normal zone: 1148 pages used for memmap
BeagleBone kernel: [ 0.000000] Normal zone: 0 pages reserved
BeagleBone kernel: [ 0.000000] Normal zone: 130560 pages, LIFO batch:31
BeagleBone kernel: [ 0.000000] CPU: All CPU(s) started in SVC mode.
BeagleBone kernel: [ 0.000000] AM335X ES2.1 (sgx neon)
BeagleBone kernel: [ 0.000000] percpu: Embedded 20 pages/cpu s53068 r8192 d20660 u81920
BeagleBone kernel: [ 0.000000] pcpu-alloc: s53068 r8192 d20660 u81920 alloc=20*4096
BeagleBone kernel: [ 0.000000] pcpu-alloc: [0] 0
BeagleBone kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129412
BeagleBone kernel: [ 0.000000] Kernel command line: console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet
Should i try to change this kernel to one better suited for my AM335x?
