rev B7 beagle board keeps on rebooting itself
My beagle board suddenly started to reboot itself, i have no clue about this.
I attach the log ,
The kernel is fine, if i load it in another beagle board, it boots fine, even in this beagle board, it boots up 3 out 10 times.
If it boots, then it crashes at twl4030_usb.
Any idea how to fix this ?
------------- log ---------------------
Texas Instruments X-Loader 1.41
Starting OS Bootloader…
U-Boot 1.3.3 (Jul 10 2008 - 16:33:09)
OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz
OMAP3 Beagle Board + LPDDR/NAND
DRAM: 128 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Audio Tone on Speakers … complete
NAND read: device 0 offset 0x280000, size 0x400000
4194304 bytes read: OK
Booting kernel from Legacy Image at 80000000 …
Image Name: Linux-2.6.27-omap1-05246-g5d103d
Data Size: 2058244 Bytes = 2 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
OK
Starting kernel …
Uncompressing Linux… done, booti.
DRAM: 128 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
OK
Starting kernel …
-----------------log ----------------------
Thanks and Regards,
HarishKumar.V
Also,
When it boots up,
it gives following messages,
It panics at twl4030 ?
DRAM: 128 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
OK
Starting kernel …
00000000, 0x0
->action(): 00000000
irq -33, desc: c03f1d28, depth: 0, count: 0, unhandled: 0
->handle_irq(): c00830b4, handle_bad_irq+0x0/0x22c
->chip(): 00000000, 0x0
twl4030: twl4030_sih_do_mask, write → -121
twl4030: gpio SIH, invalid ISR bit 23
twl4030: gpio SIH, invalid ISR bit 22
twl4030: gpio SIH, invalid ISR bit 21
twl4030: gpio SIH, invalid ISR bit 20
twl4030: gpio SIH, invalid ISR bit 19
twl4030: gpio SIH, invalid ISR bit 18
twl4030: power SIH, read ISR error -121
twl4030: I2C error -121 reading PIH ISR
twl4030: gpio SIH, read ISR error -121
twl4030_usb twl4030_usb: TWL4030:readb[0x12,0xf] Error -121
twl4030_usb twl4030_usb: USB link status err -121
omap24xxfb: Options “”
Console: switching to colour frame buffer device 80x26
omap24xxfb: fb0 frame buffer device
omap24xxfb: display mode 640x430x16
Serial: 8250/16550 driver4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
serial8250.0: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
serial8250.0: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
console [ttyS2] enabled
brd: module loaded
loop: module loaded
nbd: registered device at major 43
logger: created 64K log ‘log_main’
logger: created 256K log ‘log_events’
logger: created 64K log ‘log_radio’
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver dm9601
Linux video capture interface: v2.00
gspca: main v2.2.0 registered
usbcore: registered new interface driver conex
conex: registered
usbcore: registered new interface driver etoms
etoms: registered
usbcore: registered new interface driver mars
mars: registered
usbcore: registered new interface driver ov519
ov519: registered
usbcore: registered new interface driver pac207
pac207: registered
usbcore: registered new interface driver pac7311
pac7311: registered
usbcore: registered new interface driver sonixb
sonixb: registered
usbcore: registered new interface driver sonixj
sonixj: registered
usbcore: registered new interface driver spca500
spca500: registered
usbcore: registered new interface driver spca501
spca501: registered
usbcore: registered new interface driver spca505
spca505: registered
usbcore: registered new interface driver spca506
spca506: registered
usbcore: registered new interface driver spca508
spca508: registered
usbcore: registered new interface driver spca561
spca561: registered
usbcore: registered new interface driver sunplus
sunplus: registered
usbcore: registered new interface driver stk014
stk014: registered
usbcore: registered new interface driver t613
t613: registered
usbcore: registered new interface driver tv8532
tv8532: registered
usbcore: registered new interface driver vc032x
vc032x: registered
usbcore: registered new interface driver zc3xx
zc3xx: registered
i2c /dev entries driver
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB 1,8V 16-bit)
cmdlinepart partition parsing not available
Creating 5 MTD partitions on “omap2-nand”:
0x00000000-0x00080000 : “X-Loader”
0x00080000-0x00260000 : “U-Boot”
0x00260000-0x00280000 : “U-Boot Env”
0x00280000-0x00680000 : “Kernel”
0x00680000-0x10000000 : “File System”
usbmon: debugfs is not available
twl4030_rtc twl4030_rtc: rtc core: registered twl4030_rtc as rtc0
twl4030_rtc: Could not read TWL4030register E - error -121
twl4030_rtc: probe of twl4030_rtc failed with error -121
OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
cpuidle: using governor menu
mmci-omap mmci-omap.0: Failed to configure TWL4030 GPIO IRQ
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.17.
ASoC version 0.13.2
OMAP3 Beagle SoC init
TWL4030 Audio Codec init
asoc: twl4030 <-> omap-mcbsp-dai mapping ok
i2c_omap i2c_omap.1: XDR IRQ while no data to send
twl4030: twl4030_sih_do_edge, write → -121
ALSA device list:
#0: omap3beagle (twl4030)
TCP bic registered
TCP cubic registered
TCP westwood registered
TCP highspeed registered
TCP hybla registered
TCP htcp registered
TCP scalable registered
NET: Registered protocol family 17
NET: Registered protocol family 15
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
Power Management for TI OMAP3.
SmartReflex driver initialized
Disabling unused clock “sr2_fck”
Disabling unused clock “sr1_fck”
Disabling unused clock “mcbsp_fck”
Disabling unused clock “mcbsp_ick”
Disabling unused clock “gpt2_ick”
Disabling unused clock “gpt3_ick”
Disabling unused clock “gpt4_ick”
Disabling unused clock “gpt5_ick”
Disabling unused clock “gpt6_ick”
Disabling unused clock “gpt7_ick”
Disabling unused clock “gpt8_ick”
Disabling unused clock “gpt9_ick”
Disabling unused clock “wdt3_ick”
Disabling unused clock “wdt3_fck”
Disabling unused clock “gpio2_dbck”
Disabling unused clock “gpio3_dbck”
Disabling unused clock “gpio4_dbck”
Disabling unused clock “gpio5_dbck”
Disabling unused clock “gpio6_dbck”
Disabling unused clock “gpt9_fck”
Disabling unused clock “gpt8_fck”
Disabling unused clock “gpt7_fck”
Disabling unused clock “gpt6_fck”
Disabling unused clock “gpt5_fck”
Disabling unused clock “gpt4_fck”
Disabling unused clock “gpt3_fck”
Disabling unused clock “gpt2_fck”
Disabling unused clock “gpt1_ick”
Disabling unused clock “wdt1_ick”
Disabling unused clock “wdt2_ick”
Disabling unused clock “wdt2_fck”
Disabling unused clock “gpio1_dbck”
Disabling unused clock “gpt1_fck”
Disabling unused clock “cam_ick”
Disabling unused clock “cam_mclk”
Disabling unused clock “des1_ick”
Disabling unused clock “sha11_ick”
Disabling unused clock “rng_ick”
Disabling unused clock “aes1_ick”
Disabling unused clock “ssi_ick”
Disabling unused clock “mailboxes_ick”
Disabling unused clock “gpt10_ick”
Disabling unused clock “gpt11_ick”
Disabling unused clock “i2c_ick”
Disabling unused clock “hdq_ick”
Disabling unused clock “mspro_ick”
Disabling unused clock “mmchs_ick”
Disabling unused clock “des2_ick”
Disabling unused clock “sha12_ick”
Disabling unused clock “aes2_ick”
Disabling unused clock “icr_ick”
Disabling unused clock “pka_ick”
Disabling unused clock “ssi_ssr_fck”
Disabling unused clock “hdq_fck”
Disabling unused clock “i2c_fck”
Disabling unused clock “mspro_fck”
Disabling unused clock “mmchs_fck”
Disabling unused clock “gpt11_fck”
Disabling unused clock “gpt10_fck”
Disabling unused clock “iva2_ck”
Disabling unused clock “dpll5_ck”
Disabling unused clock “dpll4_m6x2_ck”
Disabling unused clock “dpll4_m5x2_ck”
Disabling unused clock “dpll3_m3x2_ck”
Disabling unused clock “sys_clkout1”
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
Waiting 1sec before mounting root device…
Root-NFS: No NFS server available, giving up.
VFS: Unable to mount root fs via NFS, trying floppy.
VFS: Cannot open root device “mmcblk0p2” or unknown-block(2,0)
Please append a correct “root=” boot option; here are the available partitions:
1f00 512 mtdblock0 (driver?)
Thanks and Regards,
HarishKumar.V
That one old and known-broken...
As is this one.
regards,
Koen
Koen,
Can you briefly guide me, i cannot able to get it.
Thanks and Regards,
HarishKumar.V
2009/6/14 Koen Kooi <koen@beagleboard.org>
