REV C Beagleone image flash: Won't take on different rev C boards?
I have a debian image I built with custom device tree and code that I have created. I have copied and flashed this onto new beaglebones using this tool:
http://elinux.org/BeagleBone_Black_Extracting_eMMC_contents
This worked great untill a recent shipment of BBB REV C from element 14. I can see a difference a between the two boards where the emmc chips are different the ‘old rev c’ has a kingston chip whereas the ‘new rev c’ has a different one with a number 4LA18 JWA06 and M with a circle.
When I use the tool mentioned above I get the proper led sequence tell me the emmc is being flashed (blinking once a second, then goes solid when finished). On these new board the LED sequence starts off right but goes solids very quickly and seemingly no image has been copied?
What am I missing here??
Cheers,
Matt
Nand/eMMC vary in size, the current eMMC's being used range in sizes:
#Micron 3744MB (bbb): 3925868544 bytes -> 3925.86 Megabyte
#Kingston 3688MB (bbb): 3867148288 bytes -> 3867.15 Megabyte
#Kingston 3648MB (bbb): 3825205248 bytes -> 3825.21 Megabyte
dd based image tools can't handle this. Use the rsync "flashers"...
rsync flashers? could you provide more info or link?
For this flasher image:
http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#BBB_Rev_C_.284GB_eMMC.29
This rsync based script is what runs behind the scenes..
https://github.com/RobertCNelson/boot-scripts/blob/master/tools/eMMC/init-eMMC-flasher-v3.sh
Sorry I should have been more clear.
So on a known good beaglebone that I have my custom debian installed on how do I make a copy of this on uSD card such that I flash another BBB with a different emmc chip.
Is the workflow like this:
  1. Boot up known good Kingston BBB with custom image.
  2. Insert a uSD card => 4GB
  3. execute /opt/scripts/tools/eMMC# ./beaglebone-black-make-microSD-flasher-from-eMMC.sh
  4. Insert this card into a new BBB that needs to be flashed?
Am I understanding this properly?
git pull
4. execute /opt/scripts/tools/eMMC#
5. Insert this card into a new BBB that needs to be flashed?
Correct :wink:
Thanks that worked very well.
Owe you a beer!
Kind Regards.
Hi Robert,
I am attempting this process again but now am getting:
/opt/scripts/tools# ./beaglebone-black-eMMC-flasher.sh
Error: script halting, system unrecognized…
How do I fix this?
that one is eol...
look at the previous emails..
Not sure I am following are you saying run a different script?
Sorry I am noob…
I tried the init-eMMC-flasher.sh and get the same result.
We went over this a month ago... look in the "eMMC" directory above..
and read the readme.md (git pull) to get the latest..
Ok I see now. Use the script that is /opt/scripts/tools/emmc.
One more question. The reason I was trying this tool again is that my custom debian image stopped auto connecting to my computer via usb.
I am running Ubuntu on my desktop and the little network icon just seams to be cycling thru trying to establish a connection. It never seams to quite get there.
Any ideas?
