I would wish that an extra set of along side each location of the GPIO ,
LCD, JTAG & +5V GND Power Sip pin holes could be masked off and allow for
inexpensive 2 & 4 Layer expansion / interface board . cost is way more to
get custom cables to route in an enclosure... and take to much time to
assemble..
The LCD and Expansion already allow for add-on board as does the JTAG header. Having an extra set of holes where there are already holes does not seem to add a lot of value. what exactly are you wanting to do that the current holes won’t accomplish?
We are looking to add some PWM signals to the expansion connector. This
will be valuable for robotics and other functions. We are considering
two different ways to accomplish this. Our goal is to make this as
non-disruptive as possible and to have a zero cost impact.
The current plan is to replace the following pins on the OMAP3530 with
different pins that will not change the available functions on those
expansion pins, but it will add the PWM signals to them. One side affect
is that the pin muxing will change for these pins on the Rev C. There
are ID pins on the REV C board that will allow the SW to identify if the
board is a REV C or REV B.
Already any details available how this identification can be done?
I.e. register and value(s)?
Based on that reading the drivers could set
the pin muxing accordingly to make the pins be in the correct mode. No
functionality is lost because of this change. Below are the affected
signals:
