Robert Nelson kernel: failed to register BeagleBone LCD cape LED / kobject_add_internal failed for leds-gpio with -EEXIST, don't try to register things with the same name in the same directory.
I am using Robert Nelsons kernel:
    Linux beaglebone 3.2.30-psp23
. I stacked together the following capes:
On the LCD7 cape at the place for the beaglebone I put
first the AUDIO cape, then onto that the Beaglebone.
At the place for the capes I put first the RS232 Cape
and then a breadboard cape (which currently is an empty
PCD only).
All capes have different EEPROM addresses.
When booting the kernel, I see the following messages (marked with "!!!")
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.2.30-psp23 (mccramer@solfire) (gcc version 4.7.2 (Gentoo 4.7.2 p1.0, pie-0.5.3) ) #2 Wed Oct 3 13:07:15 CEST 2012
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c53c7d
[ 0.000000] Machine: am335xevm
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 65536
[ 0.000000] free_area_init_node: node 0, pgdat c0521814, node_mem_map c0591000
[ 0.000000] Normal zone: 512 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 65024 pages, LIFO batch:15
[ 0.000000] AM335X ES1.0 (sgx neon )
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait ip=none
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] allocated 1048576 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Memory: 256MB = 256MB total
[ 0.000000] Memory: 253132k/253132k available, 9012k reserved, 0K highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] modules : 0xbf800000 - 0xc0000000 ( 8 MB)
[ 0.000000] .text : 0xc0008000 - 0xc04a4ef0 (4724 kB)
[ 0.000000] .init : 0xc04a5000 - 0xc04d0000 ( 172 kB)
[ 0.000000] .data : 0xc04d0000 - 0xc05239a0 ( 335 kB)
[ 0.000000] .bss : 0xc05239c4 - 0xc0590d94 ( 437 kB)
[ 0.000000] NR_IRQS:410 nr_irqs:410 410
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[ 0.000000] OMAP clocksource: GPTIMER1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000183] Calibrating delay loop... 331.77 BogoMIPS (lpj=1658880)
[ 0.057952] pid_max: default: 32768 minimum: 301
[ 0.058135] Security Framework initialized
[ 0.058197] Mount-cache hash table entries: 512
[ 0.058624] Initializing cgroup subsys cpuacct
[ 0.058685] Initializing cgroup subsys memory
[ 0.058746] Initializing cgroup subsys devices
[ 0.058746] Initializing cgroup subsys freezer
[ 0.058776] Initializing cgroup subsys blkio
[ 0.058807] Initializing cgroup subsys perf_event
[ 0.058898] CPU: Testing write buffer coherency: ok
[ 0.060211] devtmpfs: initialized
[ 0.080932] omap_hwmod: gfx: failed to hardreset
[ 0.097656] omap_hwmod: pruss: failed to hardreset
[ 0.098358] print_constraints: dummy:
[ 0.098663] NET: Registered protocol family 16
[ 0.099945] OMAP GPIO hardware version 0.1
[ 0.101257] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.102905] omap_i2c.1: alias fck already exists
[ 0.103332] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.103546] omap2_mcspi.1: alias fck already exists
[ 0.103668] omap2_mcspi.2: alias fck already exists
[ 0.103881] edma.0: alias fck already exists
[ 0.103912] edma.0: alias fck already exists
[ 0.104034] cape: pcm register
[ 0.115509] bio: create slab <bio-0> at 0
[ 0.116851] SCSI subsystem initialized
[ 0.117858] usbcore: registered new interface driver usbfs
[ 0.118072] usbcore: registered new interface driver hub
[ 0.118286] usbcore: registered new device driver usb
[ 0.118438] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[ 0.118621] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[ 0.119171] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[ 0.120483] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.121185] Switching to clocksource gp timer
[ 0.150207] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 0.150421] musb-hdrc musb-hdrc.0: dma type: pio
[ 0.150634] MUSB0 controller's USBSS revision = 4ea20800
[ 0.150665] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 0.150695] musb-hdrc: MHDRC RTL version 2.0
[ 0.150726] musb-hdrc: setup fifo_mode 4
[ 0.150756] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 0.151184] musb-hdrc musb-hdrc.0: USB OTG mode controller at d081c000 using PIO, IRQ 18
[ 0.151550] musb-hdrc musb-hdrc.1: dma type: pio
[ 0.151763] MUSB1 controller's USBSS revision = 4ea20800
[ 0.151794] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 0.151824] musb-hdrc: MHDRC RTL version 2.0
[ 0.151824] musb-hdrc: setup fifo_mode 4
[ 0.151855] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 0.151916] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 0.151977] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 0.152130] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.152160] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.152191] usb usb1: Product: MUSB HDRC host driver
[ 0.152191] usb usb1: Manufacturer: Linux 3.2.30-psp23 musb-hcd
[ 0.152221] usb usb1: SerialNumber: musb-hdrc.1
[ 0.153045] hub 1-0:1.0: USB hub found
[ 0.153076] hub 1-0:1.0: 1 port detected
[ 0.153625] musb-hdrc musb-hdrc.1: USB Host mode controller at d081e800 using PIO, IRQ 19
[ 0.154083] NET: Registered protocol family 2
[ 0.154327] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.154815] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.155029] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.155181] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.155181] TCP reno registered
[ 0.155212] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.155242] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.155578] NET: Registered protocol family 1
[ 0.155975] RPC: Registered named UNIX socket transport module.
[ 0.155975] RPC: Registered udp transport module.
[ 0.156005] RPC: Registered tcp transport module.
[ 0.156005] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.158081] audit: initializing netlink socket (disabled)
[ 0.158142] type=2000 audit(0.150:1): initialized
[ 0.159759] VFS: Disk quotas dquot_6.5.2
[ 0.159820] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.161132] msgmni has been set to 494
[ 0.162353] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.162475] io scheduler noop registered
[ 0.162475] io scheduler deadline registered
[ 0.162567] io scheduler cfq registered (default)
[ 0.163696] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.165313] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[ 0.793121] console [ttyO0] enabled
[ 0.797424] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[ 0.805358] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[ 0.813293] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[ 0.821136] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[ 0.829071] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[ 0.837127] [drm] Initialized drm 1.1.0 20060810
[ 0.843383] brd: module loaded
[ 0.851501] loop: module loaded
[ 0.854980] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 0.921752] No daughter card found
[ 0.925384] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 0.940673] Board config.name: A335BONE00A62712BB000768
[ 0.946197] Board name: A335BONE
[ 0.949584] Board version: 00A6
[ 0.952911] The board is a AM335x Beaglebone.
[ 0.958160] tps65217 1-0024: TPS65217 ID 0xf version 1.1
[ 0.965728] print_constraints: DCDC1: 900 <--> 1800 mV at 1800 mV
[ 0.974182] print_constraints: DCDC2: 900 <--> 3300 mV at 1275 mV
[ 0.982604] print_constraints: DCDC3: 900 <--> 1500 mV at 1100 mV
[ 0.991058] print_constraints: LDO1: 1000 <--> 3300 mV at 1800 mV
[ 0.999511] print_constraints: LDO2: 900 <--> 3300 mV at 3300 mV
[ 1.007873] print_constraints: LDO3: 1800 <--> 3300 mV at 3300 mV
[ 1.016357] print_constraints: LDO4: 1800 <--> 3300 mV at 3300 mV
[ 1.023590] omap_i2c.3: alias fck already exists
[ 1.028808] omap_i2c omap_i2c.3: bus 3 rev2.4.0 at 100 kHz
[ 1.039306] at24 3-0054: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.069793] BeagleBone cape EEPROM: found eeprom at address 0x54
[ 1.076171] BeagleBone cape: Beagleboardtoys. BeagleBone AUDIO CAPE...........Beagleboardtoys., revision 00A0
[ 1.086608] BeagleBone cape partnumber: BB-BONE-AUDI-01.
[ 1.092224] BeagleBone cape: initializing audio cape
[ 1.097595] Beaglebone cape: mcasp0 init
[ 1.101928] davinci-mcasp.0: alias fck already exists
[ 1.107513] at24 3-0055: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.137939] BeagleBone cape EEPROM: found eeprom at address 0x55
[ 1.144287] BeagleBone cape: Beagleboardtoys. BeagleBone RS232 CAPE...........Beagleboardtoys., revision 00A1
[ 1.154724] BeagleBone cape partnumber: BB-BONE-SERL-03.
[ 1.160308] BeagleBone cape: initializing RS232 cape
[ 1.165557] BeagleBone RS232 cape: only uart2/ttyO2 is supported.
[ 1.171966] BeagleBone RS232 cape: Jumper J27 and J23.
[ 1.177429] at24 3-0056: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.241790] BeagleBone cape EEPROM: could not read eeprom at address 0x56
[ 1.248992] at24 3-0057: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.279388] BeagleBone cape EEPROM: found eeprom at address 0x57
[ 1.285736] BeagleBone cape: Beagleboardtoys. BeagleBone LCD7 CAPE............Beagleboardtoys., revision 00A2
[ 1.296173] BeagleBone cape partnumber: BB-BONE-LCD7-01.
[ 1.301788] BeagleBone cape: initializing LCD cape
[ 1.307250] da8xx_lcdc.0: alias fck already exists
[ 1.312652] da8xx_lcdc da8xx_lcdc.0: GLCD: Found TFC_S9700RTWV35TR_01B panel
[ 1.333496] Console: switching to colour frame buffer device 100x30
[ 1.348571] BeagleBone cape: initializing LCD cape touchscreen
[ 1.354736] TSC connected to BeagleBone
[ 1.359161] BeagleBone cape: Registering PWM backlight for LCD cape
[ 1.365783] BeagleBone cape: Registering gpio-keys for LCD cape
[ 1.372283] ------------[ cut here ]------------
[!!! 1.377197] WARNING: at fs/sysfs/dir.c:481 sysfs_add_one+0x4d/0x68()
[!!! 1.383911] sysfs: cannot create duplicate filename '/devices/platform/leds-gpio'
[!!! 1.391784] Modules linked in:
[!!! 1.395050] [<c000f831>] (unwind_backtrace+0x1/0x8c) from [<c002c047>] (warn_slowpath_common+0x33/0x48)
[!!! 1.404998] [<c002c047>] (warn_slowpath_common+0x33/0x48) from [<c002c0a9>] (warn_slowpath_fmt+0x1b/0x24)
[!!! 1.415100] [<c002c0a9>] (warn_slowpath_fmt+0x1b/0x24) from [<c00c3929>] (sysfs_add_one+0x4d/0x68)
[!!! 1.424560] [<c00c3929>] (sysfs_add_one+0x4d/0x68) from [<c00c397d>] (create_dir+0x39/0x6e)
[!!! 1.433380] [<c00c397d>] (create_dir+0x39/0x6e) from [<c00c3a1d>] (sysfs_create_dir+0x59/0x68)
[!!! 1.442474] [<c00c3a1d>] (sysfs_create_dir+0x59/0x68) from [<c0154007>] (kobject_add_internal+0x61/0xfe)
[!!! 1.452484] [<c0154007>] (kobject_add_internal+0x61/0xfe) from [<c0154227>] (kobject_add+0x41/0x5a)
[!!! 1.462066] [<c0154227>] (kobject_add+0x41/0x5a) from [<c01a5f77>] (device_add+0x63/0x3a0)
[!!! 1.470794] [<c01a5f77>] (device_add+0x63/0x3a0) from [<c01a827d>] (platform_device_add+0x93/0xe6)
[!!! 1.480255] [<c01a827d>] (platform_device_add+0x93/0xe6) from [<c001e449>] (beaglebone_cape_setup+0x279/0x84c)
[!!! 1.490844] [<c001e449>] (beaglebone_cape_setup+0x279/0x84c) from [<c01b1813>] (at24_probe+0x26f/0x2fc)
[!!! 1.500762] [<c01b1813>] (at24_probe+0x26f/0x2fc) from [<c01f87c9>] (i2c_device_probe+0x4b/0x66)
[!!! 1.510040] [<c01f87c9>] (i2c_device_probe+0x4b/0x66) from [<c01a7569>] (driver_probe_device+0x79/0x10c)
[!!! 1.520050] [<c01a7569>] (driver_probe_device+0x79/0x10c) from [<c01a7631>] (__driver_attach+0x35/0x48)
[!!! 1.529998] [<c01a7631>] (__driver_attach+0x35/0x48) from [<c01a6b6d>] (bus_for_each_dev+0x27/0x4c)
[!!! 1.539550] [<c01a6b6d>] (bus_for_each_dev+0x27/0x4c) from [<c01a712b>] (bus_add_driver+0x87/0x168)
[!!! 1.549102] [<c01a712b>] (bus_add_driver+0x87/0x168) from [<c01a78fb>] (driver_register+0x51/0x9e)
[!!! 1.558563] [<c01a78fb>] (driver_register+0x51/0x9e) from [<c01f9943>] (i2c_register_driver+0x53/0x70)
[!!! 1.568420] [<c01f9943>] (i2c_register_driver+0x53/0x70) from [<c0008615>] (do_one_initcall+0x61/0xf0)
[!!! 1.578247] [<c0008615>] (do_one_initcall+0x61/0xf0) from [<c04a55d3>] (kernel_init+0x87/0xfc)
[!!! 1.587341] [<c04a55d3>] (kernel_init+0x87/0xfc) from [<c000cd95>] (kernel_thread_exit+0x1/0x6)
[!!! 1.596557] ---[ end trace 8c7e659a4520d827 ]---
[!!! 1.601409] kobject_add_internal failed for leds-gpio with -EEXIST, don't try to register things with the same name in the same directory.
[!!! 1.614532] [<c000f831>] (unwind_backtrace+0x1/0x8c) from [<c0154055>] (kobject_add_internal+0xaf/0xfe)
[!!! 1.624481] [<c0154055>] (kobject_add_internal+0xaf/0xfe) from [<c0154227>] (kobject_add+0x41/0x5a)
[!!! 1.634033] [<c0154227>] (kobject_add+0x41/0x5a) from [<c01a5f77>] (device_add+0x63/0x3a0)
[!!! 1.642761] [<c01a5f77>] (device_add+0x63/0x3a0) from [<c01a827d>] (platform_device_add+0x93/0xe6)
[!!! 1.652221] [<c01a827d>] (platform_device_add+0x93/0xe6) from [<c001e449>] (beaglebone_cape_setup+0x279/0x84c)
[!!! 1.662780] [<c001e449>] (beaglebone_cape_setup+0x279/0x84c) from [<c01b1813>] (at24_probe+0x26f/0x2fc)
[!!! 1.672698] [<c01b1813>] (at24_probe+0x26f/0x2fc) from [<c01f87c9>] (i2c_device_probe+0x4b/0x66)
[!!! 1.681976] [<c01f87c9>] (i2c_device_probe+0x4b/0x66) from [<c01a7569>] (driver_probe_device+0x79/0x10c)
[!!! 1.691986] [<c01a7569>] (driver_probe_device+0x79/0x10c) from [<c01a7631>] (__driver_attach+0x35/0x48)
[!!! 1.701904] [<c01a7631>] (__driver_attach+0x35/0x48) from [<c01a6b6d>] (bus_for_each_dev+0x27/0x4c)
[!!! 1.711425] [<c01a6b6d>] (bus_for_each_dev+0x27/0x4c) from [<c01a712b>] (bus_add_driver+0x87/0x168)
[!!! 1.720977] [<c01a712b>] (bus_add_driver+0x87/0x168) from [<c01a78fb>] (driver_register+0x51/0x9e)
[!!! 1.730438] [<c01a78fb>] (driver_register+0x51/0x9e) from [<c01f9943>] (i2c_register_driver+0x53/0x70)
[!!! 1.740264] [<c01f9943>] (i2c_register_driver+0x53/0x70) from [<c0008615>] (do_one_initcall+0x61/0xf0)
[!!! 1.750091] [<c0008615>] (do_one_initcall+0x61/0xf0) from [<c04a55d3>] (kernel_init+0x87/0xfc)
[!!! 1.759185] [<c04a55d3>] (kernel_init+0x87/0xfc) from [<c000cd95>] (kernel_thread_exit+0x1/0x6)
[!!! 1.768371] failed to register BeagleBone LCD cape LED
[ 1.773803] BeagleBone cape: initializing mmc
[ 1.778381] omap_hsmmc.0: alias fck already exists
[ 1.783874] BeagleBone cape: initializing w1-gpio
[ 1.788970] w1-gpio connected to P8_6
[ 1.793609] SCSI Media Changer driver v0.25
[ 1.798492] CAN device driver interface
[ 1.802551] CAN bus driver for Bosch D_CAN controller 1.0
[ 1.851837] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[ 1.858367] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
[ 1.865997] davinci_mdio.0: probed
[ 1.869628] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver SMSC LAN8710/LAN8720
[ 1.878509] usbcore: registered new interface driver cdc_acm
[ 1.884490] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.893035] usbcore: registered new interface driver usblp
[ 1.898895] usbcore: registered new interface driver cdc_wdm
[ 1.904968] usbcore: registered new interface driver uas
[ 1.910552] Initializing USB Mass Storage driver...
[ 1.915832] usbcore: registered new interface driver usb-storage
[ 1.922180] USB Mass Storage support registered.
[ 1.927185] usbcore: registered new interface driver libusual
[ 1.933807] mousedev: PS/2 mouse device common for all mice
[ 1.940277] dev addr = cf1fe808
[ 1.943634] pdev addr = cf1fe800
[ 1.947570] input: ti-tsc-adcc as /devices/platform/omap/tsc/input/input0
[ 1.955871] omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
[ 1.963134] i2c /dev entries driver
[ 1.967315] Linux media interface: v0.10
[ 1.971527] Linux video capture interface: v2.00
[ 1.976501] Driver for 1-wire Dallas network protocol.
[ 1.983367] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.991363] cpuidle: using governor ladder
[ 1.995941] cpuidle: using governor menu
[ 2.002197] Registered led device: beaglebone::usr0
[ 2.002319] Registered led device: beaglebone::usr1
[ 2.002471] Registered led device: beaglebone::usr2
[ 2.002624] Registered led device: beaglebone::usr3
[ 2.002777] Registered led device: dvi::usr0
[ 2.002899] Registered led device: dvi::usr1
[ 2.003417] usbcore: registered new interface driver usbhid
[ 2.009277] usbhid: USB HID core driver
[ 2.016143] usbcore: registered new interface driver snd-usb-audio
[ 2.027893] asoc: tlv320aic3x-hifi <-> davinci-mcasp.0 mapping ok
[ 2.039825] ALSA device list:
[ 2.042999] #0: AM335X EVM
[ 2.046508] TCP cubic registered
[ 2.049896] Initializing XFRM netlink socket
[ 2.054473] NET: Registered protocol family 17
[ 2.059204] NET: Registered protocol family 15
[ 2.063903] can: controller area network core (rev 20090105 abi 8)
[ 2.070526] NET: Registered protocol family 29
[ 2.075256] can: raw protocol (rev 20090105)
[ 2.079772] Registering the dns_resolver key type
[ 2.084808] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 2.092895] ThumbEE CPU extension supported.
!!![ 2.097473] mux: Failed to setup hwmod io irq -22
[ 2.103271] Power Management for AM33XX family
[ 2.108154] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[ 2.114929] Copied the M3 firmware to UMEM
[ 2.125244] registered taskstats version 1
[ 2.129943] Detected MACID=d4:94:a1:99:9b:82
[ 2.136047] gpio_request: gpio-51 (up) status -16
[!!! 2.136077] gpio-keys gpio-keys: failed to request GPIO 51, error -16
[!!! 2.143188] gpio-keys: probe of gpio-keys failed with error -16
[ 2.149566] omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[ 2.159027] Waiting for root device /dev/mmcblk0p2...
[ 2.202758] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 2.213226] mmc0: new high speed SDHC card at address b368
[ 2.219604] mmcblk0: mmc0:b368 TF16G 14.8 GiB
[ 2.226135] mmcblk0: p1 p2
[ 2.285888] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.294555] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.304687] devtmpfs: mounted
[ 2.308197] Freeing init memory: 172K
[ 4.884887] udevd[169]: starting version 171
[ 8.060699] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 11.504425]
[ 11.504455] CPSW phy found : id is : 0x7c0f1
[ 11.505218] PHY 0:01 not found
[ 14.503784] PHY: 0:00 - Link is Up - 100/Full
[ 21.373260] NET: Registered protocol family 10
[ 31.453338] eth0: no IPv6 routers present
[ 33.525360] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 33.906494] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
[ 33.907958] NFSD: starting 90-second grace period
With the LCD and the Beaglebone only, I can see the heartbeat on one
of the LCD LEDs. Now both LEDs are constantly bright.
One of the two LEDS on the AUDIO cape cannot be altered from userspace
(using /sys/...).
(The LCD display function is not limited by this problem.)
How can I fix the problem?
Thank you very much in advance for any help!
Best regards,
mcc
PCD only).
Well, I only have the lcd board... So since you have the hardware, and
this community has setup all the software tools/scripts for you, you
might have to get your hands dirty and look at the board file, as it
looks like it re-muxed a few pins that were already muxed with
something else..
It looks like it's one of the led's on the lcd that is already set to
something else..
Robert Nelson <robertcnelson@gmail.com> [12-10-11 19:36]:
> Hi,
> PCD only).
something else..
something else..
Robert Nelson
http://www.rcn-ee.com/
Hi Robert,
thank you for your help! :slight_smile:
The only thing which concerns me is, that a non specific part of the
the sysfs seems to create at least twice. This is not related to
a certain double-mux of a gpio but a possible kernel bug.
Only my two cent...
Best regards.
mcc
