There is a rotary encoder driver in the input driver groups. My plan was to add an encoder and make it working as a mouse wheel. The rotary encoder driver (rotary-encoder.c), is rather out of date, or had never been ported onto BBB and hence couldn’t work. Finally, I managed this to work and I want to share it, just in case someone will look for a solution as I did.
- New features:
- create an event, which is recognized as a mouse by evdev X11 driver.
- add “quarter” mode, so that every rotary “snap” is detected.
- added support for “pincontrol” pins configuration from a cape.
- Bug fixes:
- device three properties without values where not recognized (isn’t a bug in other drivers?), the problem is use the function “of_get_property” which returns NULL even though the property is defined, it returns NULL because the property has no value! I changed the code to use “of_find_property” instead.
I have a Grayhill encoder, the good quality optical one. The cheap mechanical ones, might not working ideally, and some de-bouncing/filtering might be required
I have attached the cape and driver update files. My cape is configured to use a rotary encoder on pins P8.11 and P8.15 (GPIO1_13, GPIO1_15). The switch is connected to P8.17 (GPIO0_27) and the cape configures using “gpio-keys” driver. I set this to a mouse middle button, but this event is not recognized by the evdev driver. Basically, it can be any keyboard button.
Any comment will be appreciated.
Piotr.
bbb-rotary-encoder.zip (4.04 KB)
