Well,
Thx for the advise. But i can’t find the output name for the LCD 7 CAP. The
command xrandr give:
Look in the X log, it will give you the relevant display name
screen 0: minimum 800x480, current 800x480 maximum 800x480
default connected 800x480+0+0 0mm x 0 mm
800x480 62.*
Also will it be possible with this tools ( looks like ) to rotate the
screen by 90° so that the resolution will be : 480*800.
Yes, provided the driver supports RANDR.
Why ? Because I need to put the screen vertically, that why I need to have
a resolution 480*800.
I have an another question, it is about the xorg.conf :
Section “Module”
Load “extmod”
Load “dbe”
Load “glx”
Load “freetype”
Load “type1”
Load “record”
Load “dri”
EndSection
Section “Monitor”
Identifier “Builtin Default Monitor”
EndSection
Section “Device”
Identifier “Builtin Default fbdev Device 0”
Driver “fbdev”
EndSection
Section “Screen”
Identifier “Builtin Default fbdev Screen 0”
Device “Builtin Default fbdev Device 0”
Monitor “Builtin Default Monitor”
EndSection
Section “ServerLayout”
Identifier “Builtin Default Layout”
Screen “Builtin Default fbdev Screen 0”
EndSection
I can’t figure out, where is the device touch screen and the device lcd ?
Can someone explain to us what is each section ? Thx !
These days most people tun without any xorg.conf file because it finds things
out all by itself. You only need to specify the things that you want to
override or it can not find by probing.
David
