RS232 Cape Rev B for BBB
Hi there,
Has someone used the new RS232 cape REV B before? Do you have
references on how to use it?
I need to use it to control a gsm board through AT commands and I have
no clue where to start.
Is it possible to use the older version of RS232 cape documentation as
a reference?
My basic guess and feelings are that:
I need to load a device tree overlay in order to set the pinmux, load
device drivers and the like. After that I will be able to communicate
with the other device throughout /dev/ttyAS0 and so on. Is that
correct?
Thank you!
Hi I have the same problem.
/dev/ttyOx
What jumper position are you currently using?
Maybe this will help you get started with your new RS232 Cape
http://elinux.org/BBB_RS232_Cape_RevB_Getting_Started
-Hieu
