I'm trying to build a module for beagleboard xm for WiFi rtl8192cu on
ubuntu machine, but compile fails with the following
error.
CC [M] /opt/rtl/os_dep/linux/os_intfs.o
CC [M] /opt/rtl/os_dep/linux/usb_intf.o
CC [M] /opt/rtl/os_dep/linux/ioctl_linux.o
CC [M] /opt/rtl/os_dep/linux/xmit_linux.o
CC [M] /opt/rtl/os_dep/linux/mlme_linux.o
CC [M] /opt/rtl/os_dep/linux/recv_linux.o
LD [M] /opt/rtl/8192cu.o
Building modules, stage 2.
MODPOST 1 modules
/bin/sh: scripts/mod/modpost: Нет такого файла или каталога
make[2]: *** [__modpost] Ошибка 127
make[1]: *** [modules] Ошибка 2
make[1]: Выход из каталога `/home/park/setup-scripts/build/tmp-
angstrom_2011_x-eglibc/sysroots/beagleboard/kernel'
make: *** [modules] Ошибка 2
According to the manual http://www.angstrom-distribution.org/building-angstrom
I received virtual / kernel and systemd-gnome-image.
This directory does not have a file modpost. There modpost.h,
modpost.c and others. Does anyone know how to get it?
Thanks for help.
I tried to do as it says but my directory
'/home/park/setup-scripts/build/tmp-angstrom_2011_x-eglibc/work/
beagleboard-angstrom-linux-gnueabi/linux-3.0.17-r115b/git' is empty
Thanks for help.
Try removing this line from conf/local.conf
INHERIT += "rm_work"
Then rebuild your kernel
% bitbake virtual/kernel -c cleansstate
Then you should be able to build the module/package you are having trouble with
