RTSP Gstreamer
Hi Friends.
I am facing one problem in DM355 related to RTSP Gstreamer
I am using the gst-rtsp-server(gst-rtsp-0.10.3) to transmit the video/audio encoded from server to host. I have cross compiled gst-rtsp-server and make DM355 board as RTSP server.
Then I am using examples given by the Gstremer. I am transmitting Audio file in OGG formate using "./test-launch /examples/bbb.ogg" I am trying to play files using VLC player at Client side using
On executing the above command, I get the error mentioned below.
/examples # ./lt-test-ogg bbb.ogg
** Message: listening on port 8554
** Message: added new client 0x162f0 ip 10.17.1.111:35814
** Message: attaching to context 0x13400
RTSP request message 0x96954
request line:
method: 'OPTIONS’
uri: ‘’ version: ‘1.0’ headers: key: ‘CSeq’, value: ‘11’ key: ‘User-Agent’, value: ‘VLC media player (LIVE555 Streaming Media v2010.02.10)’ body: ** Message: client 0x162f0: received a request RTSP response message 0xbeeb5bd0 status line: code: ‘200’ reason: ‘OK’ version: ‘1.0’ headers: key: ‘CSeq’, value: ‘11’ key: ‘Public’, value: ‘OPTIONS, DESCRIBE, PAUSE, PLAY, SETUP, TEARDOWN’ key: ‘Server’, value: ‘GStreamer RTSP server’ body: length 0 ** Message: client 0x162f0: sent a message with cseq 11 RTSP request message 0x96954 request line: method: ‘DESCRIBE’ uri: ‘’ version: ‘1.0’ headers: key: ‘CSeq’, value: ‘12’ key: ‘Accept’, value: ‘application/sdp’ key: ‘User-Agent’, value: ‘VLC media player (LIVE555 Streaming Media v2010.02.10)’ body: ** Message: client 0x162f0: received a request ** Message: found media 0x6bc00 for url abspath /test ** (lt-test-ogg:17348): WARNING **: recoverable parsing error: no element “theoraparse” ** Message: enter mainloop ** Message: constructed media 0x6b0c8 for url /test ** Message: preparing media 0x6b0c8 ** Message: stream 0xe2c88 received caps application/x-rtp, media=(string)audio, clock-rate=(int)48000, encoding-name=(string)VORBIS, encoding-params=(string)2, config4 ** Message: stream 0xe2c88 received caps application/x-rtp, media=(string)audio, clock-rate=(int)48000, encoding-name=(string)VORBIS, encoding-params=(string)2, config4
Can anybody help me on this?
Thanks is advance.
Kiran Thakkar
You don’t have the theoraparse element for gstreamer installed.
HI,
I have included the “theoraparse” but now I am playing the file then it hangs after following message. Nothing is audible in client side
examples # ./test-ogg 1.ogg
Streming data at rtsp://ip:port/Kiran
** Message: added new client 0x162f0 ip 10.17.1.111:64673
RTSP request message 0xd816c
request line:
method: 'OPTIONS’
uri: 'rtsp://10.17.8.131:8554/Kiran
version: '1.0’
headers:
key: ‘CSeq’, value: '5’
key: ‘User-Agent’, value: 'VLC media player (LIVE555 Streaming Media v2010.02.10)'
body:
RTSP response message 0xbea33bd0
status line:
code: '200’
reason: 'OK’
version: '1.0’
headers:
key: ‘Public’, value: 'OPTIONS, DESCRIBE, PAUSE, PLAY, SETUP, TEARDOWN’
key: ‘Server’, value: 'GStreamer RTSP server’
body: length 0
** Message: client 0x162f0: sent a message with cseq 5
request line:
method: 'DESCRIBE’
version: '1.0’
headers:
key: ‘CSeq’, value: '6’
key: ‘Accept’, value: 'application/sdp’
body:
** Message: found media 0xa3840 for url abspath /Kiran
** Message: constructed media 0xa8838 for url /Kiran
** Message: preparing media 0xa8838
** Message: stream 0x127968 received caps application/x-rtp, media=(string)audio, clock-rate=(int)44100, encoding-name=(string)VORBIS, encoding-params=(string)2, confi4
Regards
Kiran Thakkar
CTRL-A Z for help |115200 8N1 | NOR | Minicom 2.4 | VT102 | Offline
