Is there any possible way to run a DC motor of around 15 watts power using a separate power source using python in beaglebone black?
any possible solution will be appreciated. I don’t want to use any cape for the task.
thanks in advance.
thanks in advance.
Output current of a GPIO pin is around 6mA at 3.3V.
You need a Motor Driver like this one
https://www.sparkfun.com/products/9457
to do so.
If you are able to generate a PWM signal with Python it should be no problem.
