Running Ubuntu on Beagle board
I am trying to install Ubuntu on SD card using the method specified in
"http://elinux.org/BeagleBoardUbuntu#Manual_Method". While compiling
the ROOTFS i am getting many errors. I could not able to succeed. I
have tried to build ubuntu-desktop, xubuntu, lxde but i could not able
to succeed. Can anyone please respond to my below queries.
1. Is it possible to run Ubuntu on Beagle board
2. Can i get the ROOTFS image (downloadable). Any link?
Please help me.
Srinivas
1. Yes. What error's are you getting and would you pastebin your
*.log file generated by the build-arm-rootfs script?
Here is the log file contents.
I just threw this up on pastebin: http://pastebin.com/m7643521b
What OS/Distribution are you running this script with?
(I've tested it with Ubuntu 8.10/9.04 & Debian Squeeze)
Couple Notes:
Line 1264, Network failure thru Qemu, do you have any firewall's setup
or multiple connections?
My OS distro: 9.04 & there are no firewalls setup for my network
connection.
"wget " is working for me without any problem.
Srinivas
Since qemu isn't able to find the network, drop the "--seed package"
option from the command line. This should create a bare minimal root
file system. (testing as we speak)
sudo ./build-arm-rootfs --fqdn beagleboard --login ubuntu --password
temppwd --imagesize 2G
I could able to build xubuntu-desktop. But now i am unable to fetch
the below files. I am getting proxy timeout error.
wget http://www.rcn-ee.com/deb/kernel/CC-v2.6.28-79d042a-oer17
wget http://www.rcn-ee.com/deb/kernel/boot-scr/ubuntu-ext3.scr
wget http://www.rcn-ee.com/deb/kernel/boot-scr/ubuntu-ext2.scr
Is there any other way to download the same.
Srinivas
Try again, I just checked and the server's up. It's hosted wherever
micfo.com hosts their servers and should be world accessible..
Hi Robert Nelson,
I am able to run the Ubuntu on my beagle board :slight_smile: . Thanks alot for
the help.
I have one more query. I want to run Ubuntu from Flash. Can you please
provide me the steps for running Ubuntu from Flash.
Thanks & Regards
Srinivas
Good to hear!
Sorry, I haven't had a need in my applications/projects to utilize the
flash yet, but your welcome to edit the wiki page if you figure it
out. :wink: Note, there is only 256Mb of Nandflash on the beagleboard so
you'll have to choose your packages very carefully to not exceed this
limit.
Hints:
You can use "sudo apt-get clean" to remove all archived *.deb packages
from the file system to save space.
http://wiki.davincidsp.com/index.php?title=Filesystem_in_NOR_or_NAND
Is it possible to build jffs2 file system using "./build-arm-rootfs"?
Please let me know.
Thanks & Regards
Srinivas
Nope, ./build-arm-rootfs only spits out a tar/gz file, so it's up to
you to untar it and generate a jffs2 image.
Google found: http://manpages.ubuntu.com/manpages/gutsy/man1/mkfs.jffs2.1.html
