s-video on beagleboard
I am facing trouble getting s-video out to work properly on beagleboard
My setup
2.6.29 kernel the stable branch
Ubuntu distro
X server
omapfb display driver configured in xorg.conf
At u-boot
  1. See colored display
  2. When I set omapfb.mode=tv:ntsc – I see colored “beagleboard.org” displayed when kernel boots, but the X server later fails to initialize and hence gets killed
  3. When I set omapfb.mode=tv:1024x768-16@60 – I see “beagleboard.org” displayed in greyscale when kernel boots, and later X server also initializes fine. However the display is only in greyscale.
I think the issue is related to frequency or some other minor settings.
Can some one pls. list out the bootargs to be set for S-video display for Pal and ntsc tv’s
Arun
got s-video working. posting setting changes for everybody benefit…
in uboot set the following in kernel command line…i.e bootargs.
omapfb.mode=tv:ntsc
omapdss.def_disp=tv
and comment out the Driver “omapfb” and “fb” /dev/fb0 in xorg.conf.
looks like X server reconfigures the fb and that messes up everything else…
I do not have a pal tv. Can someone confirm if things work smoothly on a Pal Tv just by changing the omafb.mode=tv:pal.
-Arun
