S-Video
HI!
I would like to know if it is possible to work with beagleboard
without DVI at first, using s-video out instead. My problem is i have
ordered a beagleboard but i have no digital screen...
Thanks a lot!
Rafa said the following on 08/14/2008 02:43 PM:
see Google Code Archive - Long-term storage for Google Code Project Hosting.
Nishanth Menon
What does "echo 'tv' > /sys/class/display_control/omap_disp_control/video1"
do? Some kind of dual-head setup? Does beagleboard support PAL and NTSC, are
there different versions for different setups or can you switch in software?
I too have no digital display...
Ed
Hi Ed,
What does “echo ‘tv’ > /sys/class/display_control/omap_disp_control/video1”
OMAP Display subsystem has 3 pipelines that can be routed to either LCD/DVI or S-Video, with this command we route Video1 pipeline to S-video
I too have no digital display…
Yes, there is software support for switching between PAL and NTSC.
echo ‘NTSC_M’ > /sys/class/display_control/omap_disp_control/tv_std should change the mode.
Regard,
Khasim
