insserv: Starting led_aging.sh depends on rmnologin and therefore on system fac!
insserv: loop involving service hwclock at depth 4
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: error processing dbus (–configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of dbus-x11:
dbus-x11 depends on dbus; however:
Package dbus is not configured yet.
dpkg: error processing dbus-x11 (–configure):
dependency problems - leaving unconfigured
Setting up hostapd (1:1.0-3+deb7u2) …
insserv: warning: script ‘S18led_aging’ missing LSB tags and overrides
insserv: warning: script ‘led_aging.sh’ missing LSB tags and overrides
insserv: There is a loop between service rmnologin and mountnfs if started
insserv: loop involving service mountnfs at depth 8
insserv: loop involving service networking at depth 7
insserv: There is a loop between service led_aging and mountall if started
insserv: loop involving service mountall at depth 5
insserv: loop involving service checkfs at depth 4
insserv: loop involving service urandom at depth 7
insserv: loop involving service mountnfs-bootclean at depth 7
insserv: There is a loop between service rmnologin and mountdevsubfs if started
insserv: loop involving service mountdevsubfs at depth 2
insserv: loop involving service udev at depth 1
insserv: There is a loop at service rmnologin if started
insserv: There is a loop at service led_aging if started
insserv: There is a loop between service rmnologin and mountall-bootclean if std
insserv: loop involving service mountall-bootclean at depth 1
insserv: Max recursions depth 99 reached
insserv: loop involving service boot_scripts.sh at depth 1
insserv: There is a loop between service rmnologin and mountnfs-bootclean if std
dpkg: error processing hostapd (–configure):
Setting up openssh-server (1:6.0p1-4+deb7u2) …
dpkg: error processing openssh-server (–configure):
Setting up ppp (2.4.5-5.1+deb7u2) …
dpkg: error processing ppp (–configure):
Errors were encountered while processing:
samba
rsyslog
apache2.2-common
apache2-mpm-worker
apache2
dbus
dbus-x11
hostapd
openssh-server
ppp
E: Sub-process /usr/bin/dpkg returned an error code (1) insserv: Starting led_aging.sh depends on rmnologin and therefore on system fac!
samba
rsyslog
apache2.2-common
apache2-mpm-worker
apache2
dbus
dbus-x11
hostapd
openssh-server
ppp
