I recorded this with the interface “Port J1” on another computer.
Was that wrong ?
output_2023-05-10_16-28-51.log (4,8 KB)
Oh my fault… forgot on am335x, first line that is dumpped messes with gedit’s file opening, opens fine in kate…
Looking at:
U-Boot SPL 2019.04-00002-gc9b3922522 (Aug 24 2020 - 16:42:18 -0500)
Trying to boot from MMC2
Loading Environment from EXT4... ** File not found /boot/uboot.env **
** Unable to read "/boot/uboot.env" from mmc0:1 **
U-Boot 2019.04-00002-gc9b3922522 (Aug 24 2020 - 16:42:18 -0500), Build: jenkins-github_Bootloader-Builder-144
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
No match for driver 'omap_hsmmc'
Some drivers were not found
RTC 32KCLK Source: External.
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net: eth0: MII MODE
cpsw, usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[A335BNLT] ...
board_rev=[00C0] ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
bad MBR sector signature 0x3dbf
bad MBR sector signature 0xa68e
** Invalid partition 1 **
That is very very strange…
Where did you get these microSD cards? can i get them off amazon?
is it this one? https://www.amazon.com/Intenso-32GB-Micro-Class-3413480/dp/B008XZO0IW?th=1
Given the sizes I would assume they are 4G cards.
Are these new cards ? Could it be that the non working cards have exhausted the write cycle limit on the card and just not flashing correctly.
I have never used balena Etcher, still use old school dd. Can it verify the image written ?
Etcher does do a verify pass by default.
Good morning,
We order from different suppliers.
Pollin
https://www.pollin.de/p/intenso-microsdhc-card-4-gb-intenso-722137
Reichelt
https://www.reichelt.de/microsdhc-speicherkarte-4gb-intenso-intenso-msdhc4g-p83730.html?&trstct=pos_2&nbc=1
If it helps to find a solution, I can also send a few cards.
Many thanks for your support
