hi everyone. i have a question.
i’m following this site.
http://adis.ca/post/debian-wheezy-beaglebone-black/
but while rebooting. sdcard boot do not working & appearance emergencymode.
how can i fix it?
U-Boot SPL 2014.04-00014-g47880f5 (Apr 22 2014 - 13:23:54)
reading args
spl_load_image_fat_os: error reading image args, err - -1
reading u-boot.img
reading u-boot.img
U-Boot 2014.04-00014-g47880f5 (Apr 22 2014 - 13:23:54)
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
cpsw, usb_ether
mmc0 is current device
SD/MMC found on device 0
Failed to mount ext2 filesystem…
** Unrecognized filesystem type **
Checking if uenvcmd is set …
uenvcmd was not defined in uEnv.txt …
SD/MMC found on device 1
reading uEnv.txt
1699 bytes read in 7 ms (236.3 KiB/s)
Running uenvcmd …
reading zImage
4103240 bytes read in 280 ms (14 MiB/s)
reading initrd.img
2952586 bytes read in 169 ms (16.7 MiB/s)
reading /dtbs/am335x-boneblack.dtb
25926 bytes read in 11 ms (2.2 MiB/s)
Kernel image @ 0x82000000 [ 0x000000 - 0x3e9c48 ]
## Flattened Device Tree blob at 88000000
Using Device Tree in place at 88000000, end 88009545
Starting kernel …
[ 0.378192] omap2_mbox_probe: platform not supported
[ 0.532827] tps65217-bl tps65217-bl: no platform data provided
[ 0.596617] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 0.633725] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 0.670831] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 0.707941] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 0.722633] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 0.732256] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[ 0.739001] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 0.756546] omap_hsmmc mmc.5: of_parse_phandle_with_args of ‘reset’ failed
[ 0.819548] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
[ 0.831226] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 0.838513] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
Loading, please wait…
Scanning for Btrfs filesystems
systemd-fsck[212]: rootfs: clean, 15082/111104 files, 79776/444160 blocks
[ 6.125184] EXT2-fs (mmcblk0p1): error: can’t find an ext2 filesystem on dev mmcblk0p1.
[ 6.143156] EXT4-fs (mmcblk0p1): VFS: Can’t find ext4 filesystem
[ 6.158794] FAT-fs (mmcblk0p1): bogus number of reserved sectors
[ 6.172894] FAT-fs (mmcblk0p1): bogus number of reserved sectors
[ 6.189982] F2FS-fs (mmcblk0p1): Can’t find a valid F2FS filesystem
Welcome to emergency mode. Use “systemctl default” or ^D to enter default mode.
Press enter for maintenance(or type Control-D to continue):
root@beaglebone:~#
