SDHC?
Hello, I was wondering if anyone had any information on whether or not the beagle is compatible with SDHC cards. The manual consistently refers to SD cards, but is ambiguous as to whether this generically refers to both SD and SDHC or only SD cards.
Thank you
Beagle will support High Capacity cards provided the Kernel you use has the support for it.
What about booting from SDHC? By saying kernel support is necessary do you mean that SDHC can only be accessed after boot?
Uboot can work with SDHC, no idea about xload. For the record: I boot
of a 4GB sdhc card quite happily.
regards,
Koen
"V. Elishah Frey" <olderbolder@gmail.com> writes:
U-boot supports loading the kernel from an SDHC card. It's been said
that the ROM loader doesn't support them. I don't know about x-load.
SDHC is supported by the ROM, so you can boot from it.
Thanks very much
