Hi!
Just wondering if something's changed recently in the way the Serial Debug Header operates?
I'm asking because I've grabbed the recent release, updated to stretch, and OK yes sure added a couple of what I'd call 'basic' things in - nothing too major - but now I don't get access via the Serial Debug Header. All output looks normal on boot and I can't see anything in particular standing out in the boot log, either.
It may well be that I'm missing sufficient amounts of coffee. But any thoughts/comments appreciated at this stage.
Cheers,
Pete.
Output on Serial Debug:
U-Boot SPL 2017.03-00002-gd12b1519b4 (Mar 14 2017 - 10:28:26)
Trying to boot from MMC2
U-Boot 2017.03-00002-gd12b1519b4 (Mar 14 2017 - 10:28:26 -0500), Build: jenkins-github_Bootloader-Builder-532
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
Using default environment
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net: eth0: MII MODE
cpsw
Press SPACE to abort autoboot in 2 seconds
board_name=[A335BNLT] ...
board_rev=[00A5] ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
** Bad device 0:2 0x82000000 **
Scanning mmc 0:1...
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
1972 bytes read in 42 ms (44.9 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-4.4.68-ti-r106 ...
8608104 bytes read in 590 ms (13.9 MiB/s)
loading /boot/dtbs/4.4.68-ti-r106/am335x-boneblack.dtb ...
56827 bytes read in 88 ms (629.9 KiB/s)
uboot_overlays: add [enable_uboot_overlays=1] to /boot/uEnv.txt to enable...
loading /boot/initrd.img-4.4.68-ti-r106 ...
5940425 bytes read in 424 ms (13.4 MiB/s)
debug: [console=ttyO0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet cape_universal=enable] ...
debug: [bootz 0x82000000 0x88080000:5aa4c9 0x88000000] ...
## Flattened Device Tree blob at 88000000
Loading Ramdisk to 8fa55000, end 8ffff4c9 ... OK
Loading Device Tree to 8fa44000, end 8fa54dfa ... OK
Starting kernel ...
[ 0.001026] clocksource_probe: no matching clocksources found
[ 2.109460] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 2.291426] omap_voltage_late_init: Voltage driver support not added
[ 2.299156] PM: Cannot get wkup_m3_ipc handle
rootfs: clean, 112476/959616 files, 663500/3888512 blocks
Debian GNU/Linux 9 beaglebone ttyS0
beaglebone login:
