Serve up cloud9 via Ethernet rather than USB
How would I configure Angstrom to serve up cloud9 via a direct Ethernet connection to my laptop? I don't want to use the default USB connection.
point your web browser at the ip of the bone
i set the ip of the bone to a known static ip address
works great
Simply point to the IP address of your board with :3000 at the end, ie. http://192.168.2.35:3000, if 192.168.2.35 was the IP address of your board. You can often find this using the DHCP address table in your router configuration. If you are using a Mac or Linux machine, you can take advantage of BeagleBone broadcasting its address using Avahi/mDNS and simply point to http://beaglebone.local:3000. On Windows, you could use Zeroconf browser software like http://sourceforge.net/projects/zeroconf/ to discover the address of your BeagleBone.
