if you are using kernel 3.14.x and above, you won’t have capemgr. As said by RbertCNelson you could just install 3.8 from the debian repo:
sudo apt-get update
sudo apt-get install linux-3.8.13-bone68
sudo reboot
if you still face errors in loading pwm device trees due to missing dtbo files, use the following steps
sudo apt-get install device-tree-compiler
If you face errors with -@ option while compiling use following steps
wget -c https://raw.github.com/RobertCNelson/tools/master/pkgs/dtc.sh
chmod +x dtc.sh
./dtc.sh
get the missing dts files from
https://github.com/beagleboard/devicetree-source
now at https://github.com/venkaty89/devicetree-source/tree/master/arch/arm/boot/dts
or
https://github.com/beagleboard/devicetree-source/tree/master/arch/arm/boot/dts
compile required files using build file
#!/bin/bash
echo “Compiling the overlay from .dts to .dtbo”
dtc -O dtb -o am33xx_pwm-00A0.dtbo -b 0 -@ am33xx_pwm-00A0.dts
dtc -O dtb -o bone_eqep0-00A0.dtbo -b 0 -@ bone_eqep0-00A0.dts
dtc -O dtb -o bone_eqep1-00A0.dtbo -b 0 -@ bone_eqep1-00A0.dts
dtc -O dtb -o bone_eqep2-00A0.dtbo -b 0 -@ bone_eqep2-00A0.dts
dtc -O dtb -o bone_pwm_P8_13-00A0.dtbo -b 0 -@ bone_pwm_P8_13-00A0.dts
dtc -O dtb -o bone_pwm_P8_19-00A0.dtbo -b 0 -@ bone_pwm_P8_19-00A0.dts
dtc -O dtb -o bone_pwm_P8_34-00A0.dtbo -b 0 -@ bone_pwm_P8_34-00A0.dts
dtc -O dtb -o bone_pwm_P8_36-00A0.dtbo -b 0 -@ bone_pwm_P8_36-00A0.dts
dtc -O dtb -o bone_pwm_P8_45-00A0.dtbo -b 0 -@ bone_pwm_P8_45-00A0.dts
dtc -O dtb -o bone_pwm_P8_46-00A0.dtbo -b 0 -@ bone_pwm_P8_46-00A0.dts
dtc -O dtb -o bone_pwm_P9_14-00A0.dtbo -b 0 -@ bone_pwm_P9_14-00A0.dts
dtc -O dtb -o bone_pwm_P9_16-00A0.dtbo -b 0 -@ bone_pwm_P9_16-00A0.dts
dtc -O dtb -o bone_pwm_P9_21-00A0.dtbo -b 0 -@ bone_pwm_P9_21-00A0.dts
dtc -O dtb -o bone_pwm_P9_22-00A0.dtbo -b 0 -@ bone_pwm_P9_22-00A0.dts
dtc -O dtb -o bone_pwm_P9_28-00A0.dtbo -b 0 -@ bone_pwm_P9_28-00A0.dts
dtc -O dtb -o bone_pwm_P9_29-00A0.dtbo -b 0 -@ bone_pwm_P9_29-00A0.dts
dtc -O dtb -o bone_pwm_P9_31-00A0.dtbo -b 0 -@ bone_pwm_P9_31-00A0.dts
dtc -O dtb -o bone_pwm_P9_42-00A0.dtbo -b 0 -@ bone_pwm_P9_42-00A0.dts
chmod +x dtc.sh
./dtc.sh
copy compiled dtbo files to /lib/firmware using copy file
#!/bin/bash
cp -f *.dtbo /lib/firmware
load the required dtbo files using bash file load_dtbo
#!/bin/bash
echo “loading device trees”
export SLOTS=/sys/devices/bone_capemgr.9/slots
export PINS=/sys/kernel/debug/pinctrl/44e10800.pinmux/pins
modprobe pwm_test
echo am33xx_pwm > $SLOTS
echo bone_pwm_P8_19 > $SLOTS
echo bone_pwm_P9_21 > $SLOTS
