setting up a multi-distro SD card?
how hard is it to set up a multi-distro SD card? since i want the
option to boot to one of a set of choices of root filesystem, i'd like
to put various distros on a single SD card, so here's what i'm
imagining it would take.
  first, in the DOS partition, i would still have the files MLO,
u-boot.bin, and uImage.bin and, in a perfect world, the same uImage
file would work with all those root filesystems. is that reasonable?
as long as i create a kernel that's comprehensive enough, i'd like to
think that it can be used to mount one of a number of root filesystems
(angstrom, android, etc.), so my DOS partition wouldn't have to
change.
  from there, i could just create as many ext3 partitions as i needed
with fdisk on a sizable SD card, so that part's not hard.
  finally, it appears that i would simply need to parameterize
# printenv
mmcargs=setenv bootargs console=${console} ${optargs} \
     root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait
to select the value of "root=" every time i boot.
  is there any more to it than that? is there something subtle that
i'm not taking into account? thanks.
rday
Robert,
This would work. A few remarks though:
- you need to interrupt the boot process over serial to change the
booting rfs
- the distro's need to use the same kernel (and provide the modules
for that kernel version)
- of course you could also load a different kernel image
- you could set things up that there is a simple variable to select
which system to boot (e.g. if (os = "a) setenv bootimage
"debian.bin" ....
- if you save the variable you can even boot into the last used os
- and from that os you could use fw_setenv to change the os var. (btw:
is there a package that provides fw_setenv for the target?)
- but even better you could write a dedicated small app which you
launch which has e.g. a grub-line UI (you can start non-linux apps
from u-boot; see www.denx.de)
Let us know how you proceed (or, even better, document it in the
wiki).
Frans
Robert,
booting rfs
  if i'm always interrupting the initial boot process to drop into
u-boot and make some kind of manual selection there, this wouldn't be
an issue, would it?
  yup, i mentioned in my initial post that, in a perfect world, i
could use the same kernel uImage for every distro, but clearly, i can
always go with the pre-built, distro-specific kernel for each distro,
and slowly figure out a common config that would work for all of them.
"debian.bin" ....
  and this is where i really should read the u-boot manual to see what
i'm allowed to do and what programming constructs are available for
this. i'll let you know.
rday
