ubuntu@ubuntu:~$ cd /media/BeagleRootFS
ubuntu@ubuntu:/media/BeagleRootFS$ tar xvjf /media/106_GB_Filesystem/
Angst*.tar.bz2
tar: /media/106_GB_Filesystem/Angst*.tar.bz2: Cannot open: No such
file or directory
tar: Error is not recoverable: exiting now
tar: Child returned status 2
tar: Exiting with failure status due to previous errors
We're here to help but you have to provide more specific information.
Tell us what you did and what you observed.
Error messages are most important, if there are any.
You used tar -v so you should have seen messages for each file
unpacked. Did it start to unpack? Then what?
Best if you can cut and paste the terminal commands and output into
the email. Maybe you can use a USB key for getting the text file out
of Ubuntu if you cannot send mail from the live CD.
well, the tar.bz2 file is where you think that it are? "No such file
or directory" mean that that file doesn't exist.... check if you are
using the right place, and, if there are another files, uncompress
them individually...
The error message says the rootfs bz2 file is not stored where you
think it is stored. Remember that Linux is case sensitive.
You need to find the .bz2 file path and make sure you've got the full
path right. Use ls and cd commands to move around the filesystem and
then use the pwd command to show the current directory path when you
find the file.
ls -l /path/to/the/Angstrom*.tar.bz2
The above will show you the file size and permissions when you have
the path right.
Then do the unpack operation
cd /media/BeagleRootRF
sudo tar -xjvf /path/to/the/Angstrom*.tar.bz2
The sudo is important so it can create device nodes during the unpack operation.
