Has anyone run RAW (non X11) SGX demos over s-video?
($OMAP_SDK/GFX_Linux_SDK/OGLES/SDKPackage/Binaries/CommonRaw/Demo/)
Q1: I think I am missing something fundamental.
I can get the SGX demos to work over DVI: both with and without the X
server running, works great.
And they run over s-video BUT only with an Xserver using the X11
binaries, again works great.
They will NOT run over s-video with the raw (non X) binaries
When I try to run the non X applications over s-video they cannot
create the window surface glCreateWindowSurface()
I also noticed that the X server nulls out /dev/fb1
Q2: Is /dev/fb1 tied to s-video in any way? Is there a reference
somewhere that describes a high level architecture for /dev/fb0,1,2,
display0, display1, DVI, S-video, and lcd arcitecture...
here is a dump of the successful X11 and failed raw demo for S-video
only:
<code>
> > __ | ---'| '--.| .-'| | |
The Angstrom Distribution beagleboard ttyS2
Angstrom 2009.X-stable beagleboard ttyS2
beagleboard login: root
root@beagleboard:~# uname -a
Linux beagleboard 2.6.29-omap1 #1 Sat Jun 20 15:29:31 CEST 2009 armv7l
GNU/Linux
root@beagleboard:~# cat /proc/cmdline
console=ttyS2,115200n8 console=tty1 root=/dev/mmcblk0p2 rootwait
nohz=off omapfb
.mode=tv:ntsc omapdss.def_disp=tv vram=24M omapfb.vram=0:8M,1:8M,2:8M
root@beagleboard:~# fbset -depth 16 -rgba 5/11,6/5,5/0,0/0
root@beagleboard:~# fbset -i
mode "720x482-50"
# D: 22.153 MHz, H: 25.174 kHz, V: 50.248 Hz
geometry 720 482 720 482 16
timings 45140 80 48 3 6 32 10
endmode
Frame buffer device information:
Address : 0x8080a000
Type : PACKED PIXELS
Visual : TRUECOLOR
XPanStep : 1
YPanStep : 1
YWrapStep : 0
LineLength : 1440
Accelerator : No
root@beagleboard:~# fbset -i -fb /dev/fb1
mode "720x482-50"
geometry 720 482 720 482 32
rgba 8/16,8/8,8/0,0/0
endmode
Address : 0x8100a000
Visual : TRUECOLOR
XPanStep : 1
YPanStep : 1
YWrapStep : 0
LineLength : 2880
Accelerator : No
root@beagleboard:~# /etc/init.d/gpe-dm.mov start
Starting GPE display manager: gpe-dm
root@beagleboard:~# ./pvr/GFX_Linux_SDK/OGLES/SDKPackage/Binaries/
CommonRaw/Demo
s/ChameleonMan/OGLESChameleonMan
Exit message has been set to: "PVRShell: Unable to initialise EGL
PVRShell: EGL Error (EGL_BAD_ALLOC)
InitAPI failed!
root@beagleboard:~# /etc/init.d/pvrrc.mov start
[ 7166.141693] PVR: PVRCore_Init
[ 7166.144836] PVR: PVRCore_Init: major device 250
[ 7166.149475] PVR: Setting Debug Level = 0x4
[ 7166.154266] PVR: PVRSRVDriverProbe(pDevice=bf0d7570)
[ 7166.159393] PVR: EnableSystemClocks: Enabling System Clocks
[ 7166.165191] PVR: Setting GPTIMER11 parent to System Clock (13Mhz)
[ 7166.171386] PVR: GPTIMER11 clock is 13000000Hz
[ 7166.175933] PVR: Setting GPTIMER11 mode to posted (currently is non-
posted)
[ 7166.182952] PVR: OSUnMapPhysToLin: unmapping 4 bytes from
0xd8088040
[ 7166.189392] PVR: OSUnMapPhysToLin: unmapping 4 bytes from
0xd8088024
[ 7166.195800] PVR_K:(Error): EnableSGXClocks: Enabling SGX Clocks
[590, /mnt/de
bian/omap3-sgx-modules-1.3.13.1397/services4/system/omap3430/
sysutils_linux.c]
[ 7166.209930] PVR: CPU Clock is 1000Mhz
[ 7166.213653] PVR: SGX FClock is 55Mhz. Setting to 110Mhz now
[ 7166.219299] PVR: SGX FClock is 55Mhz
[ 7166.417816] PVR: Installing MISR with cookie bf0d85bc
[ 7166.422912] PVR: Installing device LISR SGX ISR on IRQ 21 with
cookie ce8501a
0
[ 7166.430389] PVR: OSUnMapPhysToLin: unmapping 16384 bytes from
0xd0b98000
[ 7166.437194] PVR_K:(Warning): SysFinalise: Version string: SGX
revision = 1.2.
1 [387, /mnt/debian/omap3-sgx-modules-1.3.13.1397/services4/system/
omap3430/sysc
onfig.c]
[ 7166.452117] PVR: DisableSGXClocks: Disabling SGX Clocks
[ 7166.504180] PVRSRV_PIXEL_FORMAT_RGB565
Continuing to load PowerVR services
Loaded PowerVR consumer services.
JDG - set framerate with devmem2
/dev/mem opened.
Memory mapped at address 0x4001f000.
Value at address 0x48004B40 (0x4001fb40): 0x2
Written 0x0; readback 0x0
CommonRaw/Demo
PVRShell: EGL 1.4 initialized
[ 7184.836944] no flipping
[ 7184.840179] no flipping
[ 7184.845275] no flipping
[ 7184.848419] no flipping
Exit message has been set to: "PVRShell: Unable to create surface
InitAPI failed!
root@beagleboard:~# export DISPLAY=":0.0"
CommonX11/Demo
[ 7208.144622] PVR: SysDevicePostPowerState: SGX Leaving state D3
[ 7208.150512] PVR_K:(Error): EnableSGXClocks: Enabling SGX Clocks
[590, /mnt/de
sysutils_linux.c]
[ 7208.164611] PVR: CPU Clock is 1000Mhz
[ 7208.168365] PVR: SGX FClock is 55Mhz. Setting to 110Mhz now
[ 7208.173980] PVR: SGX FClock is 55Mhz
[ 7208.177673] PVR_K:(Warning): Soft Reset of SGX [337, /mnt/debian/
omap3-sgx-mo
dules-1.3.13.1397/services4/srvkm/devices/sgx/sgxreset.c]
[ 7208.189910] PVR_K:(Warning): SGXPostPowerState : SGX Power
Transition from 3
to 0 OK [308, /mnt/debian/omap3-sgx-modules-1.3.13.1397/services4/
srvkm/devices/
sgx/sgxinit.c]
#### X11 binary runs over S-VIDEO here
cntrl-C
root@beagleboard:~# [ 7215.265960] PVR: SysDevicePrePowerState: SGX
Entering sta
te D3
[ 7215.271881] PVR: DisableSGXClocks: Disabling SGX Clocks
[ 7215.277221] PVR_K:(Warning): SGXPostPowerState : SGX Power
Transition from 0
to 3 OK [308, /mnt/debian/omap3-sgx-modules-1.3.13.1397/services4/
srvkm/devices/
sgx/sgxinit.c]
mode "720x482-50"
endmode
Visual : TRUECOLOR
XPanStep : 1
YPanStep : 1
YWrapStep : 0
LineLength : 1440
Accelerator : No
### X server blows away /dev/fb1???
mode "0x0"
geometry 0 0 0 0 0
timings 0 0 0 0 0 0 0
rgba 0/0,0/0,0/0,0/0
endmode
Name :
Address : (nil)
Visual : MONO01
XPanStep : 0
YPanStep : 0
YWrapStep : 0
LineLength : 0
Accelerator : No
root@beagleboard:~#
</code>
