SGX driver code not present
Hi Robert
Sorry to post this here but the Xchange forum has broken my login.
I used the eewiki recipe to build a kernel and to load a sd card. It all works well but when I tried to run the SGX driver installation I dont get the predicted result
Kernel_version = 4.4.3-bone-rt-r5
I ran
./sgx_build_modules.sh
You then instruct:-
Copy ./deploy/GFX_5.01.01.02.tar.gz to BeagleBone/BeagleBone Black and install
I do not have that in any directory. Is there anything special that I am missing?
Regards
Marius
then "./sgx_build_modules.sh" failed...
Initial guess:
missing 32bit lib's, since the switch to gcc-5, i've opted to not
always install the 32bit lib's by default *
sudo apt-get update
sudo apt-get install libc6:i386 libncurses5:i386 libstdc++6:i386 zlib1g:i386
*: https://github.com/RobertCNelson/bb-kernel/blob/am33x-v4.4/tools/host_det.sh#L495-L505
I am on Ubuntu 14.04 64bit. Does that matter?
probally...
When you ran:
What did it say.. ???
btw, according to my directions:
http://elinux.org/BeagleBoardDebian#SGX_BeagleBone.2FBeagleBone_Black
it's "./sgx_create_package.sh"
the sgx "modules" are pre-built and in the apt repo..
Ok that seem to have doe the trick. Thanks Robert.
Hi Robert
get
I ran
You then instruct:-
install
missing?
then “./sgx_build_modules.sh” failed…
Initial guess:
missing 32bit lib’s, since the switch to gcc-5, i’ve opted to not
always install the 32bit lib’s by default *
sudo apt-get update
zlib1g:i386
Robert Nelson
https://rcn-ee.com/
probally…
When you ran:
What did it say… ???
it’s “./sgx_create_package.sh”
the sgx “modules” are pre-built and in the apt repo…
Robert Nelson
https://rcn-ee.com/
I worked from this one https://eewiki.net/display/linuxonarm/BeagleBone+Black#BeagleBoneBlack-SGX
It says ./sgx_build_modules.sh
I did try ./sgx_create_package.sh as well before I posted. It did not work either.
I installed the 32bit libs now and recompiled. Will the 32bit libs cause trouble on the 64bit Ubuntu?
either.
both scripts require the 32bit lib's, it's just the way the *.bin was
packaged....
From the eewiki.net site, we assume you build the kernel, thus you
need to build the modules via 'sgx_build_modules.sh'..
Whereas, from the elinux site you are using everything pre-built, so
you can the modules in the apt repo and thus only use
'sgx_create_package.sh'...
No, just wasted space :wink:
pre-gcc5 the kernel script would have installed them anyways, as the
linaro 4.9 gcc was built for 32bit users too...
either.
both scripts require the 32bit lib’s, it’s just the way the *.bin was
packaged…
need to build the modules via ‘sgx_build_modules.sh’…
‘sgx_create_package.sh’…
No, just wasted space ;)
linaro 4.9 gcc was built for 32bit users too…
Robert Nelson
https://rcn-ee.com/
Yes I built everything from source so that explains then why it is different.
