Hi all,
I've got a BB xM with Ubuntu 10.10 installed. Worked fine so far,
until I tried installing the SGX acceleration, following
http://elinux.org/BeagleBoardUbuntu#SGX_Video_Acceleration
I followed all the steps and it seemed to go fine. But now on reboot
all I get for X display is a black screen (the text consoles work
fine).
Uname:
Linux mana 2.6.35.8-l7 #1 PREEMPT Wed Nov 10 12:12:44 UTC 2010 armv7l
GNU/Linux
dmesg:
http://pastebin.com/zguGyj46
Xorg log: http://pastebin.com/iRETKkF0
If I try to restart pvr, I do get the Stopping/Starting PVR, but it
doesn't fix the issue, and I see this in the dmesg:
[ 597.239746] ------------[ cut here ]------------
[ 597.239807] WARNING: at fs/proc/generic.c:810 remove_proc_entry
+0x284/0x2e8()
[ 597.239807] name 'mmap'
[ 597.239807] Modules linked in: binfmt_misc pvrsrvkm(C-) joydev
mailbox_mach smsc95xx usbhid rtc_twl mailbox rtc_core gpio_keys [last
unloaded: omaplfb]
[ 597.239898] [<c00512a0>] (unwind_backtrace+0x0/0x100) from
[<c06386f0>] (dump_stack+0x18/0x1c)
[ 597.239929] [<c06386f0>] (dump_stack+0x18/0x1c) from [<c0085818>]
(warn_slowpath_common+0x5c/
0x6c)
[ 597.239959] [<c0085818>] (warn_slowpath_common+0x5c/0x6c) from
[<c00858cc>] (warn_slowpath_fmt+0x38/0x40)
[ 597.239990] [<c00858cc>] (warn_slowpath_fmt+0x38/0x40) from
[<c01abe80>] (remove_proc_entry+0x284/0x2e8)
[ 597.240081] [<c01abe80>] (remove_proc_entry+0x284/0x2e8) from
[<bf097920>] (RemoveProcEntry+0x24/0x28 [pvrsrvkm])
[ 597.240173] [<bf097920>] (RemoveProcEntry+0x24/0x28 [pvrsrvkm])
from [<bf096f14>] (PVRMMapCleanup+0x64/0x80 [pvrsrvkm])
[ 597.240234] [<bf096f14>] (PVRMMapCleanup+0x64/0x80 [pvrsrvkm]) from
[<bf0a3970>] (PVRCore_Cleanup+0x5c/0x6c [pvrsrvkm])
[ 597.240234] unwind: Index not found bf0a3970
[ 597.240234] ---[ end trace 1b75b31a2719ed1e ]---
[ 597.261138] pvrsrvkm: module is from the staging directory, the
quality is unknown, you have been warned.
[ 597.296752] omaplfb: module is from the staging directory, the
[ 597.322296] bufferclass_ti: module is from the staging directory,
the quality is unknown, you have been warned.
Any clue someone? Did I do something wrong somewhere?
Cheers,
A.
