- I downloaded ubuntu-11.10-r3-minimal-armel.tar.xz
- executed the script setup_sdcard.sh on an Ubuntu x86 Host as
follows:
sudo ./setup_sdcard.sh --mmc /dev/sdc --uboot beagle_cx
- I installed the lastest Kernel Image following the instructions on http://elinux.org/BeagleBoardUbuntu#Install_Latest_Kernel_Image
- I made an apt-get install xfce4 gdm xserver-xorg-video-omap3 (and
maybe something more)
- I installed the SGX package I created on the x68 Host (following http://elinux.org/BeagleBoardUbuntu#SGX_Video_Acceleration)
the first run of run-SGX.sh after install worked and after each boot
all SGX modules are loaded (see dmesg on http://paste.ubuntu.com/792534/)
Then I tested the SGX acceleration with the EvilSkull demo as user
ubuntu (root makes no difference) with the immediate result in a
kernel panic (see http://paste.ubuntu.com/792545/).
This try was my last try after many attempts with ubuntu 11.04, I also
tried pre installed Ubuntu Images from https://wiki.ubuntu.com/ARM/OMAP
doing "sudo apt-get install libegl1-sgx-omap3 libgles1-sgx-omap3
libgles2-sgx-omap3", that didn't work either.
It'll take some time to pull a c4 out of production and reset for
testing, but i think i know what's causing this in 3.1.x, it was one
of the hwmod changes in 3.1, can you please retest with an earlier
kernel such as:
Thank you for your reply. I'll try your older kernel tomorrow. Today I
tried the Ubuntu way with the "ubuntu-11.10-preinstalled-desktop-armel
+omap.img.gz" image from http://cdimage.ubuntu.com/releases/11.10/release/.
This again did not work, maybe it gives some hints:
I did as suggested an apt-get install libegl1-sgx-omap3 libgles1-sgx-
omap3 libgles2-sgx-omap3 and got the following error:
Examining /etc/kernel/header_postinst.d.
run-parts: executing /etc/kernel/header_postinst.d/dkms 3.0.0-12-omap /
boot/vmlinuz-3.0.0-12-omap
Error! Bad return status for module build on kernel: 3.0.0-12-omap
(armv7l)
Consult /var/lib/dkms/powervr-omap3/4.00.00.01/build/make.log for more
information.
Yeah, sorry, i can't help you with canocial's sgx setup, i helped them
intially a few years back but haven't looked at what they are doing
now..
(armv7l)
information.
How did apply the steps above as you said with using Kernel v3.0.8-x3. Beacause, if steps is applied normally, it install Latest Kernel (3.2.24) to the system. How did you do that?
