Short cirucit ?
I have a beagleboard xM rev C.
I have a problem.
I accidentally connect the 5v pin with 156gpio pin.
The board was restarted and no more.
Doesn't flash the boot led and the black component (like a processor
but more small) closest to the processor gets hot.
The board doesn't boot.
before of that the board worked perfectly.
(sorry for my bad english)
dead beef
2012/2/20 Red Skull <redskull92@gmail.com>
Ouch! Yep. It is no longer going to work! You can request an RMA and get it repaired. There wil be a charge as the processor and the memory will need to be replaced.
http://beagleboard.org/support/rma
I saw boards where almost all ICs died after such coincidence
2012/2/20 Gerald Coley <gerald@beagleboard.org>
That is always a possibility.
How to work RMA service ?
  1. Go to the link I gave you.
  2. Fill out the form…
  3. Somebody will conntact you from the RMA team to discuss your issue.
Where is the serial of my BB ?
maybe is BB-XM-00 ?
On the box there are only Rev C and BB-XM-00
It is on a label on the back of the board.
thank you.
I live in Italy, how much does it cost to repair?
I can repair my BB only with RMA service ?
You can try to repair it yourself, but the cost of the processor and the memory and some of the other parts could cost you more than a new board. Plus, unless you have experience with soldering fine pitch BGA devices and POP parts, I am not sure that you can get it done.
How much cost the RMA services ?
It depends on the amount of damage. It may be cheaper to buy a new one. Processor and memory will be at least $25.
