Trying to upload a file “test.txt” to the BBB from my local computer
Tried all these. nothing works. What stupid mistake am I making?
Putty is running in the directory that “test.txt” resides.
the directory testing exists in the root on the BBB. I see it with ls -a
I can cd to it and find no files in it. As it should be.
I try unsuccessfully to upload a file to it. What am I doing wrong?
root@beaglebone:~/testing# cp test.txt test.txt
cp: cannot stat ‘test.txt’: No such file or directory
If your main computer is Linux, then you can cp across computers with a common network connection,
But if your main computer is Windows, for small to medium amounts of data …
I find an easy way is to cd to where you want to create the file.
then
nano test.txt
then copy the contents of the source file in a windows text editor into the copy buffer
then paste it into nano inside of putty.
Control-X to exit, Yes to save
In the reverse direction, cat the text file you want to export, copy in putty and paste into a suitable file inside of windows.
For larger amounts of data/files, you could put on a uSD card with a FAT file system and mount it in either a Windows computer or a Linux, moving the uSD card back and forth.
Or put the files/data on a USB stick formatted with FAT file system, then move the USB stick back and forth.
Putty connected via a serial connection (aka a tty) doesn't copy files from one machine to another. Look into something like scp, sftp, winscp, etc. etc. etc. Those all connect via IP though not serial.
On Mon, 8 Jul 2019 08:23:00 -0700 (PDT),
jerrywickey@gmail.com declaimed the
following:
cp: cannot stat 'test.txt': No such file or directory
When you connect with PuTTY, you are now "on" the beagle, and all
commands only know about the beagle file system.
If you have a file on the host computer, you either have to make the
host computer a mounted file system on the beagle (probably more complex
than you want to consider) OR use a file transfer program
If you are using PuTTY, you should also have it's SFTP client available
(I'm going to demonstrate with an R-Pi as I have it booted -- it's running
a web server, but other than the login and node names, both are versions of
Debian).
