I really like the Debian Stretch and Buster images but they take up the entire 4GB on BBB. Is anyone aware of slightly slimmed down derivatives of these versions?
I want to install Docker and Free Radius but there is absolutely no room!
Cheers!
Cheers!
You can grab the console image...
https://elinux.org/Beagleboard:BeagleBoneBlack_Debian#Debian_Buster_Console_Snapshot
Or even this custom image i did this week. (with docker installed by default..)
https://rcn-ee.net/rootfs/bb.org/testing/2019-12-11/buster-iot-webthings-gateway/
Going forward that image is going to be converted from docker to just
nodejs, but i needed something quick this week..
Side note, on first bootup, delete this file:
sudo rm /etc/docker.init.webthings-gateway
Then you can remove the big 1.3GB container that was pre-installed..
Thank you Robert!
I will likely run node.js inside docker images spun up via GitLab runner so that is perfect!
Cheers!
Bryan
Is there a manifest describing contents somewhere online? I am scratching my head as to why "IoT" is so much larger than "Console".
Yeap, here you go:
https://github.com/beagleboard/image-builder/blob/master/configs/bb.org-debian-buster-iot-v4.19.conf
That is really slick! I was not aware those tools were available.
Thank you Robert!
