Hi all.
I hooked up my sensirion SHT20 temp/humid sensor to my BBB.
http://www.sensirion.com/en/products/humidity-temperature/humidity-sensor-sht20/
-SHT20- -BBB-
GND —> P9-01
VDD —> P9-03
SCL —> P9-19
SDA —> P9-20
The datasheet says the address is 01000000 (0x40).
5.3 Sending a Command
After sending the Start condition, the subsequent I2C
header consists of the 7-bit I2C device address ‘1000’000’
and an SDA direction bit (Read R: ‘1’, Write W: ‘0’).
The wiring is like the following.
I expected to appear the sensor on I2C-1’s address 0x40.
But it isn’t detected:
$ sudo i2cdetect -r -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: – – – – – – – – – – – – –
10: – – – – – – – – – – – – – – – –
20: – – – – – – – – – – – – – – – –
30: – – – – – – – – – – – – – – – –
40: – – – – – – – – – – – – – – – –
50: – – – – UU UU UU UU – – – – – – – –
60: – – – – – – – – – – – – – – – –
70: – – – – – – – –
and also
$ sudo i2cdetect -r -y 0
20: – – – – UU – – – – – – – – – – –
30: – – – – UU – – – – – – – – – – –
50: UU – – – – – – – – – – – – – – –
70: UU – – – – – – –
I checked the sensor worked as a normal I2C device on my Arduino.
Do I need to install some drivers on BBB for the sensor?
Or do I missed some procedures?
