Not if you have any capes that use pull up resistors to the 3.3V EXP
voltage or any 3.3 V level that's derived from SYS5V. If you just run a
battery and no capes, it'll work fine.
This is assuming you use the P6 connector battery pins.
-Andrew
-Andrew
So I can't put a lithium battery powered Beaglebone to sleep unless I
disconnect it from the battery?Not if you have any capes that use pull up resistors to the 3.3V EXP
battery and no capes, it'll work fine.This is assuming you use the P6 connector battery pins.
Maybe I'm misunderstanding, but if the battery is connected to the
barrel jack on the Beaglbone I'm OK to put it to sleep?
- Grant
Yes.
-Andrew
