The Debian images include a fat partition for sharing drivers and documentation. Is there a way to increase the size of this partition? We would like to use the FAT partition to deploy our applications within the product.
I already tried using GParted to move the root partition and increasing the FAT partition. Booting still worked. However, GParted was not able to resize the FAT partition.
Renaming the partition is possible with GParted. However, for some reason after flashing the image to the eMMC the name of the partition is BEAGLEBONE again. Any idea how to solve that?
This is simpler at image creation time. Because the EXT partition follows the FAT partition, you need to move that EXT partition after you reduce its size, before you increase the size of the FAT partition.
Please give the steps you took, what you expected and the results.
The flashing process redoes the partitions. You’d need to change the flashing image or method.
product.
the FAT partition.
fat is hardcoded to 96Mb when "--beagleboard.org-production" is passed
to setup_sdcard.sh
this value is copied (thru /boot/SOC.sh) and used by the flasher script:
So we just need an override for boot size...
For the partition name, well this is hard coded in the flasher:
for setup_sdcard.sh we have the label option: "--boot_label" i just
need to pass it thru /boot/SOC.sh and pass it to the flasher..
I just tried changing conf_boot_endmb to 512 in the flasher script. However, it does not change the size of the partition when attached to a computer over USB. Is the value used anywhere else?
