slots file corrupt upon boot, can't echo to slots or export
Linux arm 4.4.62-ti-r99 #1 SMP Sat Apr 22 15:16:58 UTC 2017 armv7l armv7l armv7l GNU/Linux
Ubuntu 16.04
upon booting slots looks like this
cat slots
0: ------ -1
1: —l-- -1
2: —l-- -1
3: —l-- -1
i can’t write to /gpio/export or to any pin files.
i tried replacing the kernel (would prefer 4.4.59)
and Ubuntu a couple times but it’s obviously deeper then that.
need to reinstall uBoot maybe how?
really at a loss and our custom hardware is showing up tomorrow. argh!
same thing on the two BBB boards i have here at my disposal, so i spread the problem from flashing eMMC images cross them?
thanks ,
Michael
yeah, forgot the boot log
Press SPACE to abort autoboot in 2 seconds
board_name=[A335BNLT] …
board_rev=[00C0] …
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
** Bad device 0:2 0x82000000 **
Scanning mmc 0:1…
Checking for: /uEnv.txt …
Checking for: /boot.scr …
Checking for: /boot/boot.scr …
Checking for: /boot/uEnv.txt …
** Invalid partition 2 **
** Invalid partition 3 **
** Invalid partition 4 **
** Invalid partition 5 **
** Invalid partition 6 **
** Invalid partition 7 **
Scanning mmc 1:1…
1853 bytes read in 18 ms (99.6 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /boot/vmlinuz-4.4.62-ti-r99 …
8599176 bytes read in 563 ms (14.6 MiB/s)
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot.dtb] …
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot.dtb …
loading /boot/dtbs/4.4.62-ti-r99/am335x-boneblack-uboot.dtb …
53128 bytes read in 28 ms (1.8 MiB/s)
uboot_overlays: [fdt_buffer=0x60000] …
uboot_overlays: loading /lib/firmware/AM335X-20-00A0.dtbo …
378 bytes read in 40 ms (8.8 KiB/s)
uboot_overlays: loading /lib/firmware/BB-BONE-eMMC1-01-00A0.dtbo …
1105 bytes read in 171 ms (5.9 KiB/s)
uboot_overlays: loading /lib/firmware/BB-HDMI-TDA998x-00A0.dtbo …
4169 bytes read in 165 ms (24.4 KiB/s)
uboot_overlays: loading /lib/firmware/BB-ADC-00A0.dtbo …
695 bytes read in 37 ms (17.6 KiB/s)
uboot_overlays: loading /lib/firmware/univ-bbb-EVA-00A0.dtbo …
54726 bytes read in 73 ms (731.4 KiB/s)
loading /boot/initrd.img-4.4.62-ti-r99 …
6328001 bytes read in 419 ms (14.4 MiB/s)
debug: [console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=UUID=7b2b27e9-0af3-479f-b022-cd2642d6d1cd ro rootfstype=ext4 rootwait] …
debug: [bootz 0x82000000 0x88080000:608ec1 88000000] …
Loading Ramdisk to 8f9f7000, end 8ffffec1 … OK
reserving fdt memory region: addr=88000000 size=75000
Loading Device Tree to 8f97f000, end 8f9f6fff … OK
[ 4.002095] bone_capemgr bone_capemgr: Baseboard: ‘A335BNLT,00C0,2916BBBK1D39’
[ 4.009614] bone_capemgr bone_capemgr: compatible-baseboard=ti,beaglebone-black - #slots=4
[ 4.018121] bone_capemgr bone_capemgr: slot #0: auto loading handled by U-Boot
[ 4.025470] bone_capemgr bone_capemgr: slot #1: auto loading handled by U-Boot
[ 4.032803] bone_capemgr bone_capemgr: slot #2: auto loading handled by U-Boot
[ 4.040094] bone_capemgr bone_capemgr: slot #3: auto loading handled by U-Boot
[ 4.047884] bone_capemgr bone_capemgr: initialized OK.
▒ٹtxt…
board_name=[A335BNLT] ...
board_rev=[00C0] ...
Scanning mmc 0:1...
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
Scanning mmc 1:1...
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-4.4.62-ti-r99 ...
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot.dtb] ...
uboot overlays is enabled^^^
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot.dtb ...
loading /boot/dtbs/4.4.62-ti-r99/am335x-boneblack-uboot.dtb ...
uboot_overlays: [fdt_buffer=0x60000] ...
uboot_overlays: loading /lib/firmware/AM335X-20-00A0.dtbo ...
uboot_overlays: loading /lib/firmware/BB-BONE-eMMC1-01-00A0.dtbo ...
uboot_overlays: loading /lib/firmware/BB-HDMI-TDA998x-00A0.dtbo ...
uboot_overlays: loading /lib/firmware/BB-ADC-00A0.dtbo ...
uboot_overlays: loading /lib/firmware/univ-bbb-EVA-00A0.dtbo ...
Cape Universal is loaded, E(mmc), V(video/hdmi), A(audio/hdmi) pins
are Un-Available..
loading /boot/initrd.img-4.4.62-ti-r99 ...
debug: [bootz 0x82000000 0x88080000:608ec1 88000000] ...
## Flattened Device Tree blob at 88000000
   Loading Ramdisk to 8f9f7000, end 8ffffec1 ... OK
   Loading Device Tree to 8f97f000, end 8f9f6fff ... OK
'A335BNLT,00C0,2916BBBK1D39'
U-Boot
U-Boot
U-Boot
U-Boot
Another hint, that u-boot "has" control
Here is the background:
http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#U-Boot_Overlays
In it's current state, you can use "config-pin" to dynamicly change pins.
Let us know "what" pin's you want to change or what cape you want to
load and we can walk you thru it.
yes, well that makes a lot of sense. i guess I inherited that from the ubuntu flash image. my BBB dev platform only needed a led and a switch so i hand-rolled my own overlay with my own ubuntu image at the time.
but, our hardware is coming this week and i have some critical needs i have been neglecting.
I will need this week,
MMC0 with an SDIO sd-card
MMC1 with the eMMC
UART0 for booting diag, terminal
USB0 as slave for serial terminal connection
USB1 as host for cameras
it seems i have my hands full!
how do i go about this, which tools do i need, helpful links/examples? is uBoot overlays appropriate?
(i hate praying the hardware guys will let the smoke out, buying me time…)
:wink:
thanks,
michael
Well that’s pretty much the out of box setup.
Nothing special with your requirements.
well, that was the plan.
really appreciate your attention,
ciao,
Michael
